Wheel fitment
howdy quattro Sep 7, 2009
  1. howdy quattro
    howdy quattro Member
    320
    hi again lads, i'm lookin for a wheel boffin tonight, i'm thinking about putting some merc wheels on my 51 plate a4, AMG type 18's to be exact, and i was wondering if they'd bolt straight on. any ideas?? thanks!!
  2. dannyFR+tdi
    dannyFR+tdi Member
    212
    You'll need to get the sizes, stud pattern and ET to get an answer mate
  3. jwhat
    jwhat Member VCDS Map User
    541
    If the above is all the same the centre bore is probably different so you'll need spigot rings to locate on the hub properly.
  4. howdy quattro
    320
    ah yes! well i dont know what the numbers and letters mean but this is what the ad says:
    Amg alloy wheels set of 4 fronts are : 8.5j x 18 h2 et44 rears are: 9.5j x 18 h2 et46
  5. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    You will need to get 4 fronts mate, 9.5J will most likely cause rubbing issues! I might be wrong but heard few of the 'Ziners' on about it!
  6. howdy quattro
    320
    could i not roll the arches mr?? thinking of droppin it on coilovers, well, if i'm gonna fit them then i will be droppin it!
  7. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    I have been running 19"x9" front and rear's Merc rim's without any rubbing and on coilovers with a 235 tyre
  8. howdy quattro
    320
    pictures pictures pictures!!!!!
  9. John @ DW
    John @ DW Member
    300
    Both the fronts and the rears wil go on. The rears will be close and you will need to run a stretched tyre to squeeze them under, something like a 235/40/18 should do it. You might also need to take the rear arch liners out to stop rubbing, apart from that you should be ok. The wheels will be outside the arches on the back but with the stretched tyre you should be ok.
    As mentioned earlier you will deffo need some spigot rings to get them down from 66.6 to 57.1.
  10. howdy quattro
    320
    brilliant, thanks alot for that john, you've set my mind at ease!! any idea where i could get the correct spigot rings for the job??
  11. howdy quattro
    320
    nevermind! i've just got some rings ordered. lovely job!! should i put the same size tyres on all 4 wheels??
  12. RyanJonS4
    RyanJonS4 Drive It Like You Stole It
    519
    102
    43
    Is your car a quattro??
    I remember reading somewhere that if you have different rolling radius's.....which you will if fitting the same size tyres to 2 different width wheels, it can mess up your diffs.
    I'm sure someone will be along shortly to enlighten me on exactly what tho!!
    RyanJon
  13. howdy quattro
    320
    oh no!!! no more easy resting for me!!!!
