wheel fitment??
scotiamr2t Aug 31, 2011
  1. scotiamr2t
    scotiamr2t New Member
    new to the B5 A4 platform and im unsure whether the wheels i have in mind will fit. Not too much of a fan of poke although a little is acceptable
    wheels in question are 17x9.5 et25, so anyone any idea how these would sit on a B5?
    cheers
    scott
  2. tonya4
    tonya4 TDi Powerrrr
    408
    I think the et is a little low,mine are 18x8j et35 and the fronts are pretty flush with the arch.For reference you need a pcd of 5x112.
    hth
    tony
  3. Geeman
    Geeman Low Life
    1,318
    I think you'll struggle with 9.5" rims and an ET of 25.
    A chap local to me has just fitted a set of 19x9" genuine RS4 rims on his B5. They were ET50-something and he runs 20mm spacers all round. They poke out a few mm though, but he had to do that to stop them rubbing on his struts.
    With your specs, I think they'll stick out for sure.
  4. aragorn
    18,134
    764
    Geeman: ET50's are MK2 TT fitment most likely. B7 RS4's have ET24 wheels.
  5. Geeman
    Geeman Low Life
    1,318
    You're right... they are Mk2 TT fitment rims. :salute:
  6. Foxmeister
    Foxmeister Fired Up!
    1,785
    Ahem....et29 for B7's Kev!
    Geeman, got any pics of them? Would love to see genuine RS4 b7 wheels on a B5, wish it was possible!
  7. aragorn
    18,134
    764
    JCB runs B7 RS4 wheels and hes said a few times they were ET24
  8. scotiamr2t
    Cheers for the input guys, from looking at various sites an pics of wheel specs on B5's im still confused! some look exactly like how i want the fitment to be and others seem to have way more poke than i'd want.
    Think i'll bite the bullet an just go for it, bit camber along with a bit arch rolling and pulling im sure i can make it work
  9. Geeman
    Geeman Low Life
    1,318
    Here it is... 9x19 Mk2 TT rims...
    Excuse the bad photos. They do not show it off very well. He's running 20mm spacers all round.
  10. aragorn
    18,134
    764
    So thats 9" wide and a final ET of 32?
    Which means the wheels the OP mentioned would stick out 13mm more than those do.
  11. Geeman
    Geeman Low Life
    1,318
    Yeah... and these ones stick out too far for my liking (with the current tyre choice on) already!
  12. aragorn
    18,134
    764
    Yep. 9" really is too much for an A4 bodyshell. You lower the offset any more to tuck them in and you'll be hitting the uprights.
  13. Geeman
    Geeman Low Life
    1,318
    Yeah... that's why he's having to run 20's on there.
    I've got a set of 25's (bolt on's) kicking around somewhere that Ollie let me have. Never found a use for them!
  14. Foxmeister
    1,785
    True, i remember him quoting that also, but his are "winter wheel" options for B7, not sure why there is a difference in the ET, but standard UK RS4 were Et29, had looked into fitting them myself when i first got my Audi, but the 9j is the killer!
  15. Jason.s
    Jason.s Active Member
    2,879
    348
    Winters are 8j but same offset
