Wheel fitment - A6 wheels on an A3
Pez Dec 8, 2012
  1. Pez
    Pez Member
    Hi folks,
    I'm looking at getting a set of winter wheels and tyres for my A3 and have seen some on ebay from an A6. Will they fit ok?
    I've had a look at fitment guides and think A3 are 5x112, 45-50 offset, 57.1 bore. The A6 looks to be the same apart from the offset is 35-45.
    Problem is, I've no idea what an offset is!
    Thanks in advance!
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    Offset is the distance from the centre line of the wheel to the mounting face, so basically where the middle of the wheel sits relative to the hub. The lower the number, the further out the wheel will sit. ET is measured in mm, so 45-50mm from the mounting face to the centre line of the wheel.
    Wheel Offset Calculator
    The offset range is different for different widths of wheel too. A 7" wheel ET 25 would probably fit just fine, but a 9" wheel has a pretty narrow range of offsets where the wheel clears the strut on the inside edge and still fit within the arch on the outer edge.
  3. Pez
    Pez Member
    Thanks for the reply. Still not too sure though! The add just has 16" alloys with 225/45 tyres which is the same as mine, but I guess that isn't enough info.
  4. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    what is the bore on the new a3? 57.1 or 66.6?
  5. Pez
    Pez Member
  6. Pez
    Pez Member
    I just asked the seller and the wheels are ET50 6.5J so they should fit ok?
  7. MartayMcFly
    2,751
    353
    Not 100% on the new A3s. They'll fit, but might sit a bit far into the arch. What's the offset and width of the standard wheels?
  8. MartayMcFly
    2,751
    353
    Also that link isn't up to date; the new A4s are 66.6 too.
  9. Pez
    Pez Member
    Not sure, I'll have to take one off tomorrow and have a look.
    Hadn't realised that list was out of date either, although a bit more googling and it seems 5x112, 45-50 offset, 57.1 bore is right for the mk2 A3.
    Thanks for all the help!
  10. VeeDubDan
    VeeDubDan Active Member Team Monsoon
    264
    70
    MK3 not MK2 :meeting:
  11. Pez
    Pez Member
    Oh, I thought the mk3 was the new 2012 one! Mine is 09.
    Just took a wheel off and turns out they're exactly the same - ET50 6.5J:laugh:
  12. MartayMcFly
    2,751
    353
    If you have a 2009, this whole thread should be in the 8P section.
    *Thanks Sandra
