Wheel et questions
Gunny110 Feb 25, 2014
  1. Gunny110
    Gunny110 Member
    271
    19
    Hi all, I'm thinking of getting a set of 17" ZCW angel blacks for the derv. However the width is only 7j, I want the wheel to line up with the arch on the rear perfectly. My question is what et would I require to achieve this?
  2. Bradderz_1988
    3,945
    235
    Around et32/35
  3. Gunny110
    Gunny110 Member
    271
    19
    Thanks bradderz, is that 32 front 35 rear?
  4. Bradderz_1988
    3,945
    235
    Id say stick to same all round you could probably do et35 fronts and et32 rear for more rear poke/stance.
  5. Bradderz_1988
    3,945
    235
    Heres mine with ET35 boleros
  6. Oranoco
    Oranoco Well-Known Member
    3,834
    364
    ET35 is about spot on for the A4 imho.
  7. Gunny110
    Gunny110 Member
    271
    19
    Thanks lads, looking for stance as she is very low
  8. Chriscooke
    Chriscooke Clueless!
    498
    24
    For stance you'd need poke and a slight stretch if running low to really pull it off.
  9. Dimokslis
    Dimokslis Member
    65
    How about ET29 on B5? Would that come to much out? :uhm:
  10. Gunny110
    Gunny110 Member
    271
    19
    Already have about 4mm stretch on the rear, I don't want the wheels picking out, just sat nice and snug under the lip of the arch
  11. Bradderz_1988
    3,945
    235
    ET29 is RS4 spec iirc
  12. Gunny110
    Gunny110 Member
    271
    19
  13. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    My AMGs was 8.5j with 225/45 tyre was ET35. I put a 10mm spacer on the back and they lined up a lot better with the spacers than with out.
    The fronts could do with 5mm to be spot on as well.
    Gunny, you should know the ET of the wheels before buying?
    If they are 35, fit them and see how much space there is between the arch and side of the wheel to help spec up spacers.
  14. Gunny110
    Gunny110 Member
    271
    19
    Not bought them yet bud, just looking into it
