Wheel bolts
monty77 Feb 14, 2005
  1. monty77
    monty77 Member
    391
    What size bolts are in my wheels right now?
    ...replica RS6s if that makes any difference.
    Need some longer ones, going to ask Rochford 1st should they ever answer their bloody phone!
    Cheers,
    Adam
  2. dunk
    dunk Member
    770
    27.5mm i think were factory for the s3
    i uses a 42mm locking wheel nut with my oem wheels and 10mm spacers
  3. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    Cheers Dunk ... just ordered a set of 16 50mm bolts and a set of matching lockers from Rochford. Trimming may be required though.
    Cheers!
    Adam
  4. dunk
    dunk Member
    770
    50mm might catch on the suspension behind the hub - you probably will have to trim them
  5. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    Thought as much ... only did 40mm or 50mm lengths though /ubbthreads/images/graemlins/frown.gif
    Cheers,
    Adam
  6. pazaz
    pazaz Member
    323
    Just bought some new RS4 reps and was wondering if the Audi locking nuts R Ok or would any of you recommend using different ones /ubbthreads/images/graemlins/confused.gif
    /ubbthreads/images/graemlins/beerchug.gif
  7. dickys3
    2,954
    [ QUOTE ]
    [/ QUOTE ]
    Taffy, there isn't many key combinations on the Audi locking nuts (7 i think?) so you should get yourself over to halfords and get a set of McGuards. They are about £30 and are supposed to be one of the best!
    I have them on mine and I know a lot of people on here have them.
    Go get them before some scroat robs your alloys!
    Rich
  8. dunk
    dunk Member
    770
    mcguard do one that is 44mm long with the audi type of head - these fit perfectly with either spacers or a wider offset wheel
  9. monty77
    monty77 Member
    391
    [ QUOTE ]
    Adam,
    I have 15mm rear spacers on my Golf Anni.
    I'm using McGard 28017 on the rear (45.0mm) and McGard 28018 on the front (26.7mm).
    There is a groupbuy on at uk-mkivs.net for them /ubbthreads/images/graemlins/wink.gif
    [/ QUOTE ]
    Thanks mate, will prob order a set from there and flog mine on.
    Cheers!
    Adam
    PS: Your old car made 271BHP on the rollers today .. v pleased /ubbthreads/images/graemlins/smile.gif
  10. dunk
    dunk Member
    770
  11. pazaz
    pazaz Member
    323
    Are original wheel studs ok to use with RS4 reps (From Rochfords). Cause Ive just checked and only about 10mm of the thread goes into the wheel hub.
    I the checked the old Avus wheels and the stud sticks out on the hub side much more.
    Will this be ok or should I get longer ones?
    Dont fancy a wheel coming off /ubbthreads/images/graemlins/shocked2.gif
  12. pazaz
    pazaz Member
    323
    [ QUOTE ]
    [/ QUOTE ]
    Anybody?????????
