Wheel bearings
Oranoco Jan 23, 2009
  1. Oranoco
    Oranoco Well-Known Member
    3,996
    408
    Think my n/s/f wheel bearing is starting to go home as I'm sure it's droning a little. With the track day approaching I'm thinking I should sort it first. Is it a DIY job or should I drop it at my VAG man? Any wheel bearing kits to avoid as ECP do one at £19 and one at £29
  2. aragorn
    18,579
    868
    its a VERY tight fit in the hub...
    Usually these bearings are a tight push fit, requires a press or a vice and big hammer to get it out and some careful vicework or a press to get it back in. Unusually though, on the A4 there are no circlips holding the bearing into the tunnel on the steering knuckle and as such its an even tighter fit than normal.
    We did mine using a BIG hammer and vice to knock them out, and a vice and some suitably sized large sockets to press the bearing back in again.
    You need to be careful that the socket only pushes on the outside ring of the bearing. and that when refitting the hub, you support the centre race of the bearing with another socket or drift.
  3. jcb
    jcb Active Member
    4,132
    13
    I have a couple of uprights with good bearings you could just swap over.... ;)
  4. fatal8446
    fatal8446 Member
    95
    i needed an ovan and a hydralic press to get mine out, the joys of being an aircraft tech. we have them
  5. aragorn
    18,579
    868
    lol, you mustn't have had a big enough hammer ;)
    My mate was fearing for his workbench when we were beating it out, but the bench is made from 8x4" timber planks, so it stayed put :D
    I've no idea why audi chose to make them such a tight fit, instead of just fitting some circlips.
  6. Oranoco
    3,996
    408
    As much as it pains me it sounds like a job I'll have to pay to have done then as I just don't have time to muck about with it. Any idea what I should pay to get it done supply and fit?
  7. Broken Byzan
    13,237
    465
    The early ones are clip less and the later ones have clips, so you may need to remove the hiub to see what you have fitted. I found out recently i have one 85mm bearing and one 82mm since my 6 speed swap,lol
  8. Adam-D
    Adam-D Member
    457
    what about the rears? i got an advisory on the bearings, and i think my rear disks are dead as theyve gone a funky color.
  9. aragorn
    18,579
    868
    on a FWD they are old school taper bearings, like you'd find inside the drums on a ford fiesta or something. Easy enough to change, and you may as well fit new disks and pads while your there if the disks are knackered.
    Just ensure you either get disks with an ABS ring, or you aquire some new abs rings and get them pressed onto the disk before starting the job.
  10. Siena
    Siena Active Member
    2,626
    Don't the rears on a front track car have discs integral with the bearings?
  11. Adam-D
    Adam-D Member
    457
    i think they do. like my corsa track car
    ive got a horrible feeling my rear calipers have sized. goin on the color of the disks
  12. Broken Byzan
    13,237
    465
    See you can do the brakes at the same time as the suspension lol
  13. Adam-D
    Adam-D Member
    457
    i plan too, im ebaying almost everything to afford it, and to clear my garage so i can leave it in there if i dont finish
  14. Broken Byzan
    13,237
    465
    i am looking at swap mine next weekend, that still cool?
  15. Adam-D
    Adam-D Member
    457
    yes thats fine buddy
  16. aragorn
    18,579
    868
    Siena: the hub and disk is integral, but the bearing itself is just a normal taper bearing, with the little races pressed into the hub section of the disk
  17. Adam-D
    Adam-D Member
    457
    if it is the same as my corsa, i think it is i should be able to adjust it up a little
  18. aragorn
    18,579
    868
    yer its exactly the same as the setup on a corsa, but i'd take it apart and inspect/clean/regrease the rollers just to be sure. Dont want it disintegrating on you...
