Wheel Bearing
Izzy1 Jul 29, 2009
  1. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    Took my car for MOT yesterday and was told that my rear wheel bearings are loose... or may need replacing....
    Can I tighten them myself or will I need a special tool?
    also how easy are they to replace?
    cheers
  2. Geeman
    Geeman Low Life
    1,318
    Quattro or 2wd...?
  3. Izzy1
    395
    10
    2wd.
    2000 W reg A4 TDI 90BHP
  4. aragorn
    18,577
    868
    They can be tightened,the preload is set with the hub nut, but it might be an idea to strip the hubs and check the bearings/races for wear before regreasing and resetting them.
    Simply winding the nut up probably isnt the best idea.
  5. Izzy1
    395
    10
    well it's got a bit of play in the rear wheels so when the weather improves i'll try opening it up to have a look.
    will i need any special tools if i have to replace them?
  6. Fraser
    Fraser Member
    584
    they aren't expensive to replace, i paid around £96 inc vat, labour and parts for both of mine recently
  7. aragorn
    18,577
    868
    The bearings are about a tenner each.
    To remove and grease them you need nothing more than basic tools, some pliers, screwdrivers and an adjustable spanner for the hub nut, 13mm spanner for the caliper bolts and a 8mm hex key for the carrier (you might prefer to use a hex key that attaches to a ratchet though as they are pretty tight)
    Just make sure that when you tighten them, you only just "nip up" the nut, dont go winding it on as tight as you can, just enough to remove the play.
    A useful guide is that you should be able to move the thrust washer with a screwdriver and there should be no play feelable with the wheel fitted.
  8. Izzy1
    395
    10
    thanks guys,
    good thing i can do it with basic tools.
    will let you know when i attempt it and how i get on.
  9. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    oooh yeh... buggered knuckles, even managed to twat me elbow off the upper suspension arm last time........:rock:. Bring on the TCP!!!!
    Sorry Izzy.. Good luck. :O)
  10. Izzy1
    395
    10
    think i'll need the 1st aid kit at hand then.... thanks for the heads up.
  11. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Izzy, spray the hex bolts holding the carriers with plus gas or wd40 for a few days before atempting to remove and make shure you have a long breaker bar and a very good quality 8mm hex socket. Make shure you dont round the bolt head off and the bearing kit is £15+ VAT each in euro car parts(trade price). Go to local halfords store and buy a tub of bearing grease(about a fiver) and clean the abs ring with a wire brush to remove rust. You will also need a long solid screwdriver and a heavy clubhamer to knock the races off the hub. Also make shure you pay attention to the way the bearings go as they conical and are a very tight fit ! Put plenty grease in the hub.
