Wheel Bearing
A3DOL Feb 15, 2009
  1. A3DOL
    A3DOL Member
    97
    Hi All,
    Anyone changed a front wheel bearing on a 54' plate A3 Tdi?
    Getting louder now and needs sorting. Fancy having a go myself.
    Gav
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    pay a garage to do it, the old one will need pressing out and the new one pressing in, not something you can do yourself unless you have a press.
    Also you'll need the geo checked on the car afterwards incase anything has moved.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    havent done one on an A3 but without a hydraulic press you going to need a variety of large drifts/old sockets, acetylene to heat things and a very large hammer. You could keep costs down by removing the hub yourself and get your local garage to do the hard part.
  4. Khufu
    5,704
    31
    you must type faster than me LOL
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    As far as I know the bearings do not need pressed - you buy the whole unit from audi and they are around £75 each
    That goes for the rear bearings but I have never priced or asked about the fronts but I presume they are similar!
    The rears are an easy change over!
  6. Khufu
    5,704
    31
    you will still need to get the old bearing out the hub even if the new bearing comes with the part you bolt the wheel to comes attached.
  7. NHN
    29,351
    1,720
    Yeah as far as I remember from when I did mine on my S3 that was the old 8L, you now buy it as a whole unit now & it bolts on, so no pressing needed, removing needed as such, I will consult with the Oracles(namely etka/elsa)
