Wheel Bearing Removal Kits
Ian2012 Sep 9, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    Has anyone used these kits that pull the front bearing wheel out and push a new one in without taking the hub off the car? are they worth the money?
    Ian
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    is this made for the Audi?
    as the bearings (yes theres two) are pressed on to the hub and the whole lot bolts in then I can't see them working
  3. Ian2012
    473
    29
    ok i get it i thought there was just one big bearing a bit like old school audi 80/90 etc
  4. stu_m
    1,441
    year there is actually two bearings and one is a different size to the other and the shaft on the hub is stepped too
    In my experience I would buy the hub complete with bearing and replace the lot as one
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    The front bearings are part of a replaceable assembly which unbolts - as opposed to other cars (i.e-fiestas) where the bearing needs to be pressed.
    Take a look at this thread;
    DIY: Front wheel bearing replacement
    swarcup likes this.
  6. madmike01uk
    madmike01uk Member
    430
    21
    are they quite simple to do? I think mine may need doing but I'm not sure if it's not just noisy front tyres.
  7. AlexGSi2000
    1,464
    199
    I took mine out when I replaced the upright - I would say its straight forward yes.
    The guide I linked to above has it pretty much spot on.
  8. stu_m
    1,441
    its a little fiddly but can easily be done
    I replaced the bearing and holder rather then the whole hub and bearing next time I will be replacing the whole hub though
  9. Ian2012
    473
    29
    Oh my god AlexGSi what a find thank you so much
  10. Mike_B
    Mike_B Active Member
    533
    47
    Note the ref to a press!
