Wheel bearing brand
neilA4 Oct 22, 2013
  1. neilA4
    neilA4 Member
    206
    Hi does anyone know what brand audi use for their wheel bearings. I'm guessing the cheap ones on eBay won't last? Cheers
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    Would like to know this also as im looking to do both fronts
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    theres more than one company which supply to audi
    i make and roll the steel which is supplied to the bearing companies who then supply audi
    nsk bearings and skf dormer are two i can remember off hand
  4. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,461
    199
    I would stay away from cheap brands on ebay - buy cheap buy twice.
    Stick to the decent brands, as mentioned above, I have used SKF in the past.
    Eurocarparts should stock decent brands.
    May even be worthwhile getting a price from Audi themselves, I have often found parts cheaper by going to Audi as opposed to eurocarparts.etc
  5. Bradderz_1988
    3,901
    230
    SKF or FAG !!
  6. neilA4
    neilA4 Member
    206
    Are snr any good? Eurocarparts has 25% off at moment. Could do both fronts for £120
  7. Bradderz_1988
    3,901
    230
    Personally ive never used them but iirc they are a well known decent brand !!
  8. dualmono21
    1,132
    schaeffler are one of the other brands we make steel for ...they produce the fag bearings
    snr are part of the danish ntn group , not made by us but still good quality
  9. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    I put an SKF one on mine just over a year ago
    it needs doing again!!!
  10. swarcup
    1,326
    40
    anyone used continental contitech?
  11. AlexGSi2000
    1,461
    199
    Didn't know Contitech did wheel bearings - I thought they just did belts?
  12. swarcup
    1,326
    40
    Have gone for Meyle at £54 each. See how they go
  13. ricostuart
    ricostuart Active Member
    409
    43
    Got a cheap one off the motor factors (FAG I believe) and it was a pretty quality part. ***** to remove the old one!
  14. neilA4
    neilA4 Member
    206
    good price, where from? cheers
  15. neilA4
    neilA4 Member
    206
    just to check, my symptoms are a rumbling noise more audiable above 40mph, like a quiet motorbike lol. noise not related to engine speed, no noise from gearbox in any gears.
    just the faster I go the louder the rumbling. also I think I can feel some vibration on the accelerator pedal, but strangely not other pedals.
    Possibly driver side bearing.
    oh, and 207,000 miles !
    sound about right?
  16. neilA4
    neilA4 Member
    206
    Well ordered the snr bearings from Ecp and skf ones turned up!
    all done now had to take housing off as the bearing was seized in both sides! If anyone wants torque values From memory the 4 off bearing bolts were 80nm plus 90deg, the driveshaft bolt 16mm was 200nm plus 180deg, the brake carrier was 190nm, the brake sliders were 30nm, the top pinch bolt for upper arms is 40nm and the tie rod bolt is 45nm and bottom ball joints were 110nm
    All from elsawin
    oh and the noise has gone car is smoother and quieter
