Wheel arch rub with spacers on S3 8P3 (all else OEM)....Any solutions??
warren_S5 Dec 29, 2011
  1. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    And by solutions I don't mean take spacers off!!
    In brief:
    Car is running OEM S3 wheels / tyres / suspension.
    Car is running 11mm Forge spacers front and rear.
    With 5 people in the car the tyres are rubbing at the rear under heavy suspension compression.
    Will changing arch liner bolts resolve, or do I need to change suspension and modify ride height? (I was hoping to drop 20mm, not raise 10mm!!!)
    Any advice appreciated, TIA!
  2. ERICS3
    ERICS3 Member
    34
    Hello,
    I had the same problem with 20mm momo spacers front anda rear anda with people in the car the tyres are ruburing at the rear.
    I have OEM suspension anda now 19"8x5 wheels 235/35 tyre and no more ruburing because the tyre hit a screw inside the rear bumper. You need to work inside the rear bumper.
  3. warren_S5
    7,210
    2,487
    I'll whip out an arch screw out and get a flat headed replica for starters, thanks for the heads up.
  4. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,063
    572
    if you're geting it lowered then set the camber -1° 30". i think that should work, i'm runing 12mm front pretty much low and no rubing. on the rear i also replaced screw, i'm thinking of putting 15mm's back :D
  5. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,262
    359
    i would take out the "screw" that seams to be the plague of the 8P mine was catching before she was lowered so i took that out and only get the odd catch rarely when going round a bumpy corner but thats because it is lowered take the screw out and you should be all good mate
  6. warren_S5
    7,210
    2,487
    I'll get to it this afternoon! Doing my head in. People who I was driving thought it was their fault the car was dragging its **** s they now have a weight complex!
  7. FranA3
    7,262
    359
    haha they'll all be on a diet now lol , its a torque bit (hex bolt) if i remember correctly i don't think audi would have changed it can't remember the size maybe T30 but don't quote me on that
  8. N8
    17,163
    719
    If you ain't rubbin, you ain't dubbin :wub:
    pinterovski likes this.
  9. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    523
    39
    change jobs to a lap dance club..........
    then if you give any of the workers a lift im sure they wont make ya back end rub lol........
  10. marknjayne
    marknjayne Member
    425
    mine rub too,,,dose anyone have a pic of the offending screw
  11. TimG
    TimG Active Member
    942
    45
    Options are:
    Remove screw and trim bracket slightly
    Increase -camber (mines at 2 degrees currently)
    Run narrower tyres with a slight stretch
    Run smaller spacers
    Firm up the rear shocks
    Dont put people in the back
    Raising the ride height is NOT an option, ever [​IMG]
    br20vt and pinterovski like this.
  12. TimG
    TimG Active Member
    942
    45
    There is only 1 screw it can possibly be mate, where the bumper meets the 3/4 panel.
  13. marknjayne
    marknjayne Member
    425
    think i know the one,just wanted it confirming bud
  14. N8
    17,163
    719
    Changes when you get air though :laugh:
  15. FranA3
    7,262
    359
    here is the location of the offending screw for ya'll
  16. marknjayne
    marknjayne Member
    425
    Cheers Fran,thought it was that one :salute:
  17. FranA3
    7,262
    359
    no probs mate
  18. warren_S5
    7,210
    2,487
    :beerchug:
    good man Fran
  19. FranA3
    7,262
    359
    no worries dude saves any confusion to where it is doesn't it :photo:'s don't lie do they ;)
  20. Scott
    Scott Well-Known Member
    1,306
    126
    I think it's T25 not T30 mate..........although they might both work as I doubt there's much difference lol
  21. FranA3
    7,262
    359
    thanks for the dislike scott :( but yeah either will work i suppose lol
  22. Scott
    1,306
    126
    Lol what the.....absolutely no idea how that happened!!!
  23. FranA3
    7,262
    359
    haha sure sure lmao
  24. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,365
    203
    So..............Scott doesn't like Fran eh.....I seen it with my own eyes....
    and Warren ???? how old are you :whistle2: you will be blanking the rear wiper next :)
    theo289 likes this.
  25. warren_S5
    7,210
    2,487
    Yup, and I've got a 'roll hard' sticker to go down the side of the windscreen
    @ N8
    Something I saw at ADI 2011
  26. TimJK
    TimJK Member
    429
    Mine also does this on 12mm rear H&R spacers. May have to check out this screw today as lowering springs are on their way to me!
  27. bendhamrait
    bendhamrait Member
    61
    Chaps i have s-line 18" wheels, wanted some 10 or 12mm spacers, will i get any rub? not lowered just all standard
    cheers ben
  28. pandoo1
    pandoo1 Member
    93
    Guys Im suffering from major rubbing :( I have this set-up atm, sat on Eibach Pro Kit springs 50mm at the front and 40 at the back with staggered wheels..8x18 ET35 with 225/40 and 9x18 ET45 with 235/40.
    I had these for the past two weeks and Im experiencing major rubbing, its getting even worse as the springs are settling :'( Is there anyway of stopping this from happening or will I just have to change the springs?
  29. s3ollie
    s3ollie Member
    762
    I have 15mm spacers at the rear on standard 2007 S3 wheels, screw removed with no rub at all. :yes:
  30. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    My spacers are going on tomorrow so I'll just take the screw out as I am down 25mm on H&R springs and will be fitting coilovers in spring :)
  31. TimG
    TimG Active Member
    942
    45
    Yes, read my post #11 above.
  32. poli84
    poli84 Member
    425
    57
    I have H&R 12mm spacers sitting there ready for install also.
    Thought I wouldn't have any rubbing issues with 225's, appears not.
    Will remove the screw at install. Hopefully it's not bad as coilovers are my next mod.
    Thanks for the tips above.
  33. TimJK
    TimJK Member
    429
    I replaced the screw with a less narrow one as didn't want to remove it completely. Because I don't want to hit a bump and the tyre knock the side of the bumper out of the retaining clip. It's reduced rubbing but still present. May have to keep trying smaller screws until it goes.
    Annoying really as my Leon Cupra r was lowered 30mm and had 15mm spacers with no rubbing.
  34. pandoo1
    pandoo1 Member
    93
    So even with the set up I have removing the screws and trimming the bracket could help? But what bracket are you talking about and which screws? Lol noob here.
  35. TimG
    TimG Active Member
    942
    45
    Again, look at Frans Post above with the photo! :)
    Do what I do and reverse up a kerb incline so that just the back wheel tucks right up into the arch. This will let you see exactly where its rubbing and whether you stand a chance of remedying it by removing the screw and trimming the bracket that the screw goes into! TBF its not gonna hurt your chances getting that screw out anyhow, takes 5 seconds to do!
  36. WALTO TDI
    WALTO TDI Member
    293
    12
    i have 15mm spacers on mine, its lowered on coilovers but on standard wheels. i get a slight rubbing but nothing major. i will remove the screw tomorrow and then let you know how it is. 15mm spacers look good as the wheels fill the arches now!!!
  37. theo289
    theo289 Member
    293
    great thread...had the same issue with my audi and it looks like it is the screw. i would be interested in putting a replacement into the car so does anyone have a replica/ something which will fill the gap?
    Thanks!
