whats this?
joss Jul 24, 2009
  1. joss
    joss Member
    214
    hello i have a knock when i pullup and looking under the car the bush on this seems to be the problem..questions are what is it, whats the part number, how hard would it be to do on my own and how much are they.
    cheers
    joss
    ps 96 audi a4 2.6 quattro
  2. joss
    joss Member
    214
    pic no working, hold on one sec
  3. joss
    joss Member
    214
  4. Lee Goodall
    Lee Goodall Active Member
    2,279
    It's the lower control arm.
    Not too hard to replace but the ball joint can be a pain to shift.. a blow torch or heat gun is a big help.
    Not sure on the part number but a good quality one would be about £40 on it's own AFAIK.
  5. Geeman
    Geeman Low Life
    1,318
    Front lower control arm.
    Not too difficult to do on your own, but helps if you've got a ramp.
  6. Geeman
    Geeman Low Life
    1,318
    Beaten to it!
    But yeah, £40 is about right.
  7. joss
    joss Member
    214
    cheers dudes.
  8. joss
    joss Member
    214
  9. Lee Goodall
    2,279
    I think the only difference is the quality between the two hence the price difference. Must be two different manufacturers.
  10. joss
    joss Member
    214
    cheap it is in then:rock:
  11. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    buy cheap buy twice with these normaly.
  12. joss
    joss Member
    214
    buy cheap cause no money..:(
  13. jcb
    jcb Active Member
    4,132
    13
    or get some poly bushes and replace the crappy ones in your exisiting arm...cheaper still!
  14. aragorn
    18,608
    871
    I baught cheap ones last year, they lasted about 3 months, before wearing out so much they wrecked both front tyres. When i took them off, they were worse than the arms they'd replaced.
    Buy lemforder or Meyle, or you'll be back under there again in not much time at all.
  15. jcb
    jcb Active Member
    4,132
    13
    buy powerflex and you won't remember being under there
  16. ian52
    1,199
    with the cheap ones it seems to be the ball joint that goes and you cant replace that. thats what went on my original audi ones too not the bushes.
  17. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Get Lemforder(OEM) or Meyle heavy duty arms and you wont feel sorry. Also replace the droplinks with the genuine items as they dont have balljoints but bushes and they are lasting much longer.
  18. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    what he said Lemforder OE i got mine from here fast delivery
  19. jcb
    jcb Active Member
    4,132
    13
  20. joss
    joss Member
    214
    i'll see what the good quality ones from gsf are.
  21. rasA4
    3,287
    119
    i would stick to Lemforder or Meyle imho
