What's This??
Sulli79 Feb 11, 2012
  1. Sulli79
    Sulli79 Active Member
    541
    37
    Found this under the airbox cover on a 1.8t AJL, is it a pressure sensor? looks like it broke and somebody attempted a fix with glue?
  2. Bradderz_1988
    3,945
    235
    It's the purge canister Solenoid valve.
    Mines the same and has been repaired with glue and it's not air tight though but at £75 iirc I left it how it was as I will be installing a catch can at some point.
  3. aragorn
    18,036
    724
    You dont NEED to fix it, but if you intend on leaving it like that, remove the hose from the other side and block it off so your not drawing in unmetered air.
    Leave the bit thats currently broken open to the atmosphere so the tank can breathe.
  4. Sulli79
    541
    37
    Cheers Guys.
  5. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    They all break eventually... Mines been left electrically connected so I don't get any fault codes.
