Whats this reddish stuff !
vw754 Apr 25, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    found on my 2001 1.9 pd tdi awx engine.All this reddish dust what is it?
  2. james0808
    james0808 Active Member
    3,548
    Could be a water leak?
  3. terrysingh
    terrysingh Member
    184
    thats just very fine rust particles, your cam running gear is galvanised and where the belt sits this wears out, leaving the car sitting around for a while will cause a slight amount of surface rust and this is removed by the belt when you drive it.
    the cam gear only starts to get like this if you dont drive your car much or if you've given the engine a wash!
    are those cracks in your belt?
  4. james0808
    3,548
    Better go and check mine,might need a clean.I hardly ever drive mine.
  5. vw754
    2,345
    58
    nooooooo no water leak,had cambelt done it were all dry just reddish dust.
  6. terrysingh
    terrysingh Member
    184
    just check the belt, dont clean anything, its easyier cleaned when everything is off, the dust if very fine nothing to worry about unless your belt looks knackered!!!! i've changed the belt of a A2, golf mk4, volvo s80 with a vw engine, quite easy as long as you've got instuctions, the correct tools, and maindealer service bit,
    a mate of mine got cheapy stuff from ECP and 2 weeks later the belt decided to loose 16 teeth.... nice
  7. terrysingh
    terrysingh Member
    184
    vw754 is that a pic of your old belt???
  8. dan_b
    dan_b Member
    263
    Get that belt changed :scared2:
  9. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    You saying your cambelt is new??
  10. 46TheDoctor
    46TheDoctor Valentino Rossi A.K.A The Doctor
    312
    That belt aint new!, its covered in cracks and there gonna bite you in the ass if not sorted.:wacko:
  11. vw754
    2,345
    58
    sorry,i just borrowed that pic,my belt looks alot better than that.:salute:
  12. J7USS
    3,737
    77
    :thumbsup:
