What's the ride like with fitting H&R lowering springs 25ml?
tmcentee525 Feb 7, 2010
  1. tmcentee525
    tmcentee525 New Member
    10
    Whats the ride like with fitting H&R lowering springs 25ml?
    cheers
  2. EvolutionV
    EvolutionV Member
    203
    Which car have you got mate? A3/S3 Petrol / Diesal
  3. tmcentee525
    10
    s3 58 plate mate
  4. david_phillips95
    david_phillips95 Member VCDS Map User
    504
    With my S3 it is near enough the same as standard, the springs are progresive so they stiffen up if your cornering hard etc
    Davie
  5. tmcentee525
    10
    cheers mate have you got spacers on your?
  6. david_phillips95
    504
    nope not running spacers at the moment, something i might look into.
    Davie
  7. N8
    17,163
    718
    The ride is alright, but not as good as coilovers.
  8. david_phillips95
    504
    I cant imagine coilovers being as comfortable a ride as the OEM dampers, coilovers are always going to be firmer even on there softest damping setting. Iv always thought coilovers were for people looking to go mega low or a track enthuasiast, not someone who uses there car to nip around town and commute to work lol
    Davie
  9. heyadamhey
    heyadamhey Member VCDS Map User
    126
    I have the 35mm H&Rs and the ride is good. Progressive, like Davie says. Almost feel softer than my SE springs under normal driving, but that 'semi-softness' gets firmer quickly.
    Cornering and turn-in is MUCH better than stock
  10. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Ride is very good.
    Very slightly stiffer than OEM but not certainly not a `hard` ride.
    Just MUCH better all round.
    cheers
    Paul
  11. DPM
    DPM Site Sponsor Site Sponsor
    4,963
    193
    As mentioned the H&R springs are very similar to the standard ride quality, just better handling. Coilovers will definitely be stiffer again over the standard ride.
    Damian @ DPM Performance
  12. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    damian - how much will you supply a set of H&R springs and front and rear anti roll bars for?
  13. N8
    17,163
    718
    My coilovers on softest setting were bouncey as hell, so deffo more comfy over standard oem setup, but now on half way hard, they are just perfect man, if you were local I'd take you out in mine..
  14. DPM
    4,963
    193
    £635 :icon_thumright:
