What's the problem here when I cut engine off?
vw754 Jan 15, 2010
  1. vw754
    vw754 vorsprung Durch Technik
    2,346
    58
    My car used to cut off smoothly when i parked it up but latley its doing this...any ideas?
    If i press the clutch pedal in and keep it there and switch engine off it cuts out smoothly.
    ITS MY FIRST VIDEO POST,THINK IVE GONE WRONG SOMEWHERE.MY....APPOLOGIES.
    CLICK ON THE ACTUAL PICTURE TO PLAY THE VIDEO
    2.0 tdi 140 [​IMG]
  2. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,062
    572
    seem that everyones a3/s3 is doing it. when you press down clutch and turn it off it goes off smoothly. and if you don't it sound like it's falling apart.
  3. vw754
    2,346
    58
    Nice to know im not alone then:beerchug:
  4. I always thought it was just the gears in the gearbox rattling as they come to a stop, this would explain why the noise goes away when you dip the clutch. Just an idea mind you.
    Davie
  5. mrgicm
    mrgicm Phantom black S3/
    137
    This happens when you flywheel is in a bad shape or damadged. This use to be my problem, changed the flywheel and all OK!!!!!
  6. NHN
    29,561
    1,778
    flywheel
  7. vw754
    2,346
    58
    thanks for all the replys,will it last a while or is this a warning,car drives ,idles, ok ive no other problems
  8. mrgicm
    137
    The sooner you change it the better, so that your clutch doesnt hold any extra pressure/damage... and also you car should go a little better than.. :)
  9. My car is booked in on the 25th January for the clutch to get replaced with my sachs perfromance one. I will find out what state my DMF is in then as it will be exposed, I would be surprised if my DMF was faulty as i have had this noise since i bought the car with less than 5000 miles. Maybe some flywheels are noiser than others but i wouldnt say that this noise means your flywheel needs replaced. If your flywheel was on the way out you would get vibration through the clutch pedal.
    Davie
  10. S.
    2,062
    572
    mine does it since day one.
  11. vw754
    2,346
    58
    mines been doing it a few months,il leave it be,il replace complete clutch kit flywheel and release bearing if it ever goes.
  12. The flywheels must wear out within the delivery mileage, that would explain it :laugh:
  13. S.
    2,062
    572
    will be replacing it when it won't hold power anymore.
  14. Sounds like a good idea to me :)
  15. S.
    2,062
    572
    well for now it's ok. but will go for twintercooler and maybe fuel pump so i think it will be necessary :racer:
