whats the most likely boost leak location?
danger S3 Aug 3, 2010
  1. danger S3
    danger S3 Member
    374
    19
    hey, does anyone have pics of what the most likely places for boost leaks are and where they are in the engine?
    also how do you go about pressure/smoke testing the system?
    cheers
    Ali
  2. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    Want to know this my self :)
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Under the inlet manifold (all the vac hoses down there), busted DV, and intercooler/s where the core joins the end cap.
  4. Matt82
    Matt82 Active Member
    2,365
    a greed. id say most common is under the inlet manifold
    the rest take some looking into
  5. danger S3
    danger S3 Member
    374
    19
    cool thanks, I'll check it out under the inlet manifold, are they easy enough to see or is there anything particular i can do to get better access or to test them?
  6. Matt82
    2,365
    take the n249 tray off to get better access
  7. Welly
    10,696
    129
    Thats the only way to be able to see properly. Two allen key bolts, BE CAREFUL of the dipstick shroud - it will most likely be brittle and break.
  8. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    is this the same on the A3 or there other places? i just wanna make sure before i get my remap. Also does vagcom show if ur missing boost at all?
