What's that rumble sound?!?? :/
supanova Mar 13, 2013
  1. supanova
    supanova A3 2.0 TDI SE
    539
    22
    Heard a rumble sound when driving off and slowing down or going slow ie about 10-15 mph in the photo, a) is this the rubber bushing and b) should this have movement or should it stay solid and not move.
  2. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Looks like a bottom arm bush.
    It shouldn't have any play in it but it will move if forced as it's rubber, don't change just one do both sides if it is worn
    You can upgrade to polyurethane.
  3. supanova
    539
    22
    would this make the rumbling sound or am I lookin in the wrong direction altogether?
  4. adamss24
    adamss24 Well-Known Member
    4,584
    406
    That won't rumble mate, is your's a quattro ?
  5. supanova
    539
    22
    Nope just b7 a4 avant 2.0l Tdi se.
  6. RMH1A4cab
    551
    19
    That's bottom bush would make a knocking sound and the steering would feel a bit disconnected if it was badly warn.
    So is this noise still there if you put the car into nuteral and free wheel, this is to check is its drive train related.
    Are your tires Ok, my previous car an S2000 used to make and awful sound where there tires were worn/going off.
    Jack the up and put your foot against the bottom of the wheel and pull the top of the wheel towards you see if there is any play.
  7. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    3,119
    1,858
    That was my thought too. Our VW Jetta does this when the rear tyres are worn. Had it on previous cars too.
  8. supanova
    539
    22
    No it's not the tyres for definite!! I sounds more like a metal rattle, like something is loose or worn.
  9. supanova
    539
    22
    no ideas guys?
  10. Avnt
    Avnt Active Member
    240
    25
    Wheel bearing
  11. supanova
    539
    22
    Umm not too sure. is sounds like metal rumbling together like something is loose. I replace a wheel bearing on the drivers side last month. could it be anything else?
  12. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Does the rumble / noise go away when you turn the steering wheel?
    A
  13. Avnt
    Avnt Active Member
    240
    25
    Brakepad fouling on the disc. That gave me a rumbling sound
  14. supanova
    539
    22
    The rumble only happens when im coasting/slowing down, coming to a stop or taking off slowly. like a jingle rattle as if something needs tightened. :/
  15. Molnboman
    1,338
    193
    Disnae sound like a bearing from my experience then. Could be something between your pads and disc ( gravel, gunk etc ) I have always been very reluctant to do this, however, I was recommended by my garage to give the brake/ discs a good, careful "blootering" with a pressure washer ever now and again on my Avant.
    Good Luck and keep us posted
    A
  16. supanova
    539
    22
    I always thought that a wheel bearing gave off a humming sound? Although I'm not very technical when it comes to cars mind you. the brakes do feel like they could be doing with a new set. ( a bit of travel when braking ). and the disc do look a bit worse for wear. If i jack the car up and push/pull the wheel to see if there is any play/movement, will this determine if its the wheel bearing?
  17. Avnt
    Avnt Active Member
    240
    25
    Ye youd feel movement. If ur due some brakes its a good chance that is it. It did on my volvo at the rear but it sit it all the time. Changed disc and pads nice and quiet now apart from the drop links knocking their tits off lol
  18. Steve220
    Steve220 Member
    234
    15
    Wheel bearings can make a droning sound or a rumbling sound depending on how far they are gone. If it makes it more when steering one direction then it will be side dependant. Brakes will only make a rumbling sound if you have no pads left.
