whats that 'pinging' sound on start up?
jazzyc Jun 22, 2007
  1. jazzyc
    jazzyc Member
    153
    when i first start my car in the morning i get a 'pinging' sound. It repeats itself about 4 times then stops. i dont think i get any warnings on the dash or anything and it dosent do it throughout the rest of the day, only on first start up.
    sorry for what maight seem daft questions but i dont have a handbook with my car and dont know what half the things do:think:
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    seatbelt warning?
  3. AndyMac
    9,832
    45
    4 beeps from the rear of the car is normally an indication that the backup battery in the alarm module is struggling, and/or the car battery could be on its way out
  4. jazzyc
    jazzyc Member
    153
    well its defo 4 beeps and only when i start it first thing in the morning.
    so is there a battery i need to change on the alarm module? is it your normal run of the mill battery?
    car allways starts fine by the way.
  5. jazzyc
    jazzyc Member
    153
    :ermm: dont think my car does this. I have not noticed anything on the dash when i start the car and have not put my seat belt on.
    should there be some kind of warning or showing on the display?
    once again sorry for all the lame questions but i am still trying to source a handbook to let me know whats what.
  6. ronny
    ronny Audi A4 1.8TQ
    131
    Car battery on it's way out, try using jump leads to start the car, even though the battery is not dead that surge in power is enough to trigger that alarm, try the jump leads and see if it goes away, if it does you need to replace your battery as it will soon fail, if it doesn't, then you will have to look into somthing else.
  7. AndyMac
    9,832
    45
    I'd start with the main battery as ronny suggests - the current draw from starting the car can be enough to drop the voltage on the alarm so it thinks someone is tampering with the battery. If you still get the beeps with a jump start then it could be the alarm module battery, but this is a more involved job, either replacing the alarm module itself (£80) or taking it apart and replacing the rechargeable batteries inside - not standard, but some people have done it.
  8. jazzyc
    jazzyc Member
    153
    thats a blow then. It seems i am looking at a new battery:sadlike:
  9. AndyMac
    9,832
    45
    £70 for a new Bosch Silver top - not really the end of the world, cheaper and more useful than buying a new alarm module.
  10. jazzyc
    jazzyc Member
    153
    where would that be from?
    halfords? audi?
    not as bad as i thought
  11. hiltoa
    hiltoa VAG erfahren
    298
    WOAH GUYS!!!
    It's just the back-up batteries in the alarm...
    If you're willing to dismantle the alarm, it's around £12 for 2 cell batteries from Maplin.
    Info here!
    More specific info here!
    Did mine last month, no more 'quad-beep' on start, definately nothing wrong with my car battery!
  12. jazzyc
    jazzyc Member
    153
    wow that seems to be it!
    I have just had a right set to over the phone with the guy i bought it from telling him it needed a battery!
    can you tell me exactly where it is on my a4. in the boot on the left hand side i pull the flap down and remove the tool kit that is in there. then where do i look?
  13. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    you have an avant or saloon? in my B6 its behind a trim panel on the o/s behind the wheel arch.
    If you ping the siren open you will see the cells, just replace them as stated earlier, make sure you're handy with a soldering iron.
  14. jazzyc
    jazzyc Member
    153
    mine is a b5 (2000) face lift model. saloon
    i thought it was behind the trim panel on the left hand side but cant see anything.
  15. Caesium
    4,879
    try the drivers side, right down in the well.
  16. AndyMac
    9,832
    45
    I didn't suggest go and buy a new battery, just what the cost would be. The suggestion was try it with jump leads to another car with the engine running and eliminate the main battery as this is easy to do and will then point the finger firmly at the backup batteries.
  17. jazzyc
    jazzyc Member
    153
    thats where it was:applaus:
    i have now split it apart and got the batterys out. They did look quite corroded.
    just need to find somewhere local that has them now.
    I take it the car is ok to drive around in while this is dissconected?
  18. macattax
    macattax Member
    455
    No the car might explode!:haha:
    Nah seriously them batterys are hard to come by as the company went bust a few years back.
    I got a new siren on ebay germany for €30 or so a while back.
    Or do as Hiltoa said in the links he posted above (i think he said halfords has an alternative)
  19. macattax
    macattax Member
    455
    Found this one on ebay its diffrent from my one but it does say its for a B5.
    Should do the job.
  20. hiltoa
    hiltoa VAG erfahren
    298
    Maplins stock appropriate cells that fit (with simple tweaks as per first link in my post above).
    Stock number BN24B = £5.99 each, you will need 2.
    @ macattax - that ebay link appears to be for the horn, not the alarm.
  21. macattax
    macattax Member
    455
    Ahh yeah I was thinking it looked totally different lol.
    Well go with hiltoas plan as there are none on ebay germany im afraid.
  22. jazzyc
    jazzyc Member
    153
    yeah i have tried a couple of battery suppliers and none of them do anything.
    trip to maplins it is then.
    thanks for the help guys
  23. Caesium
    4,879
  24. jazzyc
    jazzyc Member
    153
    WHICH ONES AM I LOOKING FOR? THEY GOT OVER A 1000 ON THERE (sorry for caps)
  25. jazzyc
    jazzyc Member
    153
    i have tried to search under button cells etc but i dont think they do ones that ar thick enough. most they seem to go to is about 5mm and i think the ones we need are 11.5mm
    course i could be missing them.
  26. hiltoa
    hiltoa VAG erfahren
    298
    Maplin - BN24B
    None of the cells shown on CPC appear to be the right size (search on Batteries, NiMH, Button cell type, then filter by 3.6v)
  27. jazzyc
    jazzyc Member
    153
    i am wondering if this is all become to much agro. I have it all out and apart but getting the batteries is a hassel. Might just leave it out or try and get one from scrappy.
  28. shineydave
    shineydave Member
    920
    isn't there enough room inside to fit something like the recharchable batteries from a cordless phone?. the type that come with a pair of leads attached. all you'd need to do was attach the wires to the metal terminals where the + and - terminals on the battery touched.
    in fact, better idea, solder 2 wires, run them outside the alarm case and buy a seperate battery holder. that way the next time they go it's just a matter of changing the batteries, don't even need to open the case up
    i'd be tempted to try one of these
    http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=battery&Ntx=mode%20matchpartial&N=4294729709&name=SiteStandard&forwardingPage=line&R=4725517&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0687621473.1182680169@@@@&BV_EngineID=ccckaddlfikedgfcefeceeldgkidhgj.0&cacheID=ukie
    and one of these
    http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=44392&doy=24m6
  29. jazzyc
    jazzyc Member
    153
    could be worth a go.
    does the battery meat all the requirements?
    amp needs to be 160-170 i think dosent it and the the originals were 2 x 3volts and this is 9 volts
    does any of this make a difference?
  30. shineydave
    shineydave Member
    920
    hmmmmmmmmmmmm the link doesn't work
    anyway, it's on the RS components webshite
    part number 472-5517
    8.4v 150mAh
    the standard batteries would be 7.4v and 160mAh so it'll be close enough plus it makes it a doddle to change the battery the next time it goes
  31. jazzyc
    jazzyc Member
    153
    Your links worked for me?
    anyways, i think your idea could be worth a try
    thanks
  32. jazzyc
    jazzyc Member
    153
    well credit goes to shineydave for this one but this is what i came up with.
    seems to do the job, time will tell how long the battery will last.
    nice and simple to change anyway:)
  33. shineydave
    shineydave Member
    920
    it needs to be a NiMH really as a conventional battery isn't designed to be recharged but all credit to you, that looks a neat job. does it work ok then?
  34. jazzyc
    jazzyc Member
    153
    i have only put it in this afternoon so we will need to see.
    so i really need to put a rechargable one in there then?
    will this do any harm in there for a couple of days untill i sort one out?
    its not going to bugger anything else up is it?
  35. hiltoa
    hiltoa VAG erfahren
    298
    It will only bugger stuff up if it:
    A. pops due to excess hydrogen build up within the cell, spraying its alkali guts around.
    B. fries any circuitry in the alarm that's not rated to 9v (remember the original batteries were 7.2V combined).
    Still, if you don't try, you'll never know...
  36. jazzyc
    jazzyc Member
    153
    better get a different one today to be sure then. I take it that the one i buy off the shelf will not have much charge in it. When fitted the system will charge it up then right??
  37. shineydave
    shineydave Member
    920
    i'm not sure, never bought recharchables before. i've just ordered a NiMH one and battery holder from RS to have a go at Tonyas, i'll report back before the end of the week.
  38. jazzyc
    jazzyc Member
    153
    well i went and got a ni-mh today to fit, it was only £3 so no dramas there. The other one that i fitted seems to be fine at the moment though, started fine this morning with no ping ping ping ping so thats good news and i have not heard anything go bang yet so even better.
    will still fit the ni-mh just to be sure though.
  39. shineydave
    shineydave Member
    920
    but does the alarm sound if you drop a window, arm the alarm and wave an arm about in the cabin? you have to wait untill the red led in the lock button starts flashing steady, about 30 seconds or so after you arm the alarm
  40. jazzyc
    jazzyc Member
    153
    I have never heard the alarm go off yet so good chance to give it a try.
    will let you know:icon_thumright:
