whats next to gain more power from AGU lump...?
Pete69zx Oct 20, 2006
  1. Pete69zx
    Pete69zx Guest
    I have an AGU engined A3 1.8T
    It has somesort of remap fitted by a company that i forget the name of now (already done by previous owner).
    It has a Forge DV fitted (alteast i think its a Forge).
    It has a Miltek system (unsure if its just CAT back).
    I have been told by the previous owner that it is around 220BHP (cannot confirm this)
    Anyways, the car has ample power & is quite responsive.
    I just want to know what is next to up the power some more?
    Would i need to consider ways of cooling the intake temperature before i think about more power?
    The car just has the standard SMIC & all OEM pipework.
    Cheers, Pete.
  2. KEF A3 20V T
    KEF A3 20V T Turbo's Rule
    199
    I cannot see that pulling 220BHP. mine is pritty much the same and its pulling 195 ish!
    for any more power you need a bigger turbo, either:
    1. ko3s, 220 ish
    2. k04 hybrid 260 ish fits standard manifold but needs injectors etc..
    3. k04-023 270/280 need new exhaust manifold, injectors,maf etc,etc
    4. Garrett gt28, up to 300/330 need fcuking loads of stuff looking at £4K
    i am in the process of collecting all the gear for a K04-023, decent gain and all OEM S3 parts to upfit so should be reliabe. will be bout £1500 all fitted with custom remap
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,041
    212
    Yeah, it won't be anywhere near 220. The next on your shopping list would be a bigger turbo for power but then that comes with having to change alot of other things.
  4. Pete69zx
    Pete69zx Guest
    Thanks for the replys guys.
    Hey Kev, i see your not too far from me.
    What you upto tomorrow night, fancy meeting up to talk cars and stuff? :)
    I have just finnished having my facelift headlights fitted & want to test em out in the dark, lol
    Pete.
  5. KEF A3 20V T
    199
    yea rite you do! for a k04-023 u need:
    • injectors green top 440s if you use s3 ones u need spacers for rail +4 bar fpr
    • Bigger maf
    • tip
    • turbo and exhaust manifold off BAM engine
    • OEM cats or Race cat
    • 3" dp
    • FMIC
  6. Pete69zx
    Pete69zx Guest
    Sounds expensive already! LOL
  7. dummi
    dummi smoking a6
    1,210
    spray pattern is better of OEM s3 injectors would be best
  8. Pete69zx
    Pete69zx Guest
    so, could i just add some s3 injectors, and get the car RR'd?
    would that increase performance a little?
  9. tommo-turbo
    tommo-turbo Member
    164
    I think you'd have to increase the fuel pressure too with a fuel pressure regulator or an uprated pump. What type of fuel pump's do A/S3's use?
  10. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    No point unless your maxing out your standard ones,which i doubt you are,i'm not yet.
  11. KEF A3 20V T
    199
    Andy you know what hp the s3 injectors max out can they take up to 280 bhp? and do you need spacers to fit them into a AGU head
  12. dummi
    dummi smoking a6
    1,210
    next for horse power IMO are
    k04 direct replacement
    s3 injectors with oem 4 bar fpr
    remap
    you don't need fuel pump the standard is sufficient for that
    optionally at the same time FMIC and samco tip for reliability
    the next stage would be big turbo which would need £4k
  13. KEF A3 20V T
    199
    av sorced a k04-023 turbo and manifold off a 2001 tt so just wondering what injectors to use< i thort bosch 44o's would be fine with 3 bar fpr! btut ppl say they have a **** spray pattern! is the a oem 4 bar fpr like? Part number??
  14. ANDYTQ
    1,186
    106
    I have heard 440's are not ideal also ie spray pattern,i have also heard that there are some porsche ones that are better suited and i don't think they need spacers either.Theres a few peps on seatcupra.net running aggressive st2 lcr maps and seem to get 280 on standard injectors.Jabba recommended s3 /lcr injectors for ko4 hybrid,its harder to map with 440's apparently.
  15. DPM
    5,041
    212
    If the remap is done correctly then you'll only need a 3 bar fpr.
