What's needed for stage 3 on s3 8p
katenick Jul 17, 2013
  1. katenick
    katenick New Member
    17
    Hi guys I'm stage 2 plus already just wondering what's need for stage 3 ??
    any help would be appreciated !
    thanks nick
  2. S3Alex
    10,589
    4,659
    Have a read through my build thread and that will give you a stage by stage breakdown of what's required and a rough idea of costs.
    It's a bit if a read but if you have any questions I'm happy to help.
    As a starter you will need a big turbo kit which will run to £5-7k and you need to ensure you've done the brakes and suspension first.
  3. coreythorny
    coreythorny Active Member
    463
    74
    unless he means Shark stage 3 which is stage 2+
  4. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,253
    586
    After stage 2, the whole stage thing is clutching at straws. What do you want from your car is the question? My next ugrade would be larger injectors and a Loba 400 turbo,
    Rick
  5. katenick
    katenick New Member
    17
    Would like to see 400 if poss ?
  6. Rick @ Unicorn Motor Dev.
    1,253
    586
    Then you need the turbo and injectors :)
    Rick
  7. katenick
    katenick New Member
    17
    Is that it ? No need to forge it ? Any recommendation on turbo ? Also what injectors and who to map ?
  8. S3Alex
    10,589
    4,659
    No need for forged internals up to around 440lbs torque.
    Loba is good for around 400-440bhp
    GTX2876 is good for around 440-480bhp and anything else you need a lot of work and you'll see anywhere up to 500bhp+.
    Mapping....I used Revo but APR and GIAC also map to this level although with APR you will need their kit,and Rick,Shark and others may do as well.
    Have a trawl through my thread and any other BT threads here and be sure to choose someone who knows what they're doing.
  9. S3Alex
    10,589
    4,659
    Nicely put.
    What its called doesn't matter,but what does matter is choosing the exact spec and what you require now,and in the future,as we all want more!
    The Loba is a very good 400+bhp choice,but if you eventually want more,it would be limited,but it will take you as far as you can go without an engine rebuild.
  10. nluk100
    nluk100 Active Member
    916
    163
    43
    Just to clarify for the OP, there is a LO400 and a LO4xx turbo by Loba - the second one requires injectors and can make upwards of 400 depending on other components. The LO400 is a rework of the std K04 and can just about make 400 but has a better spool than OEM. Depends what you want, power or drivability. Alex, where does the torque peak on your turbo?
  11. Rick @ Unicorn Motor Dev.
    1,253
    586
    For a genuine 400 you need injectors unless you want to run it at lambda 0.95 which isn't a good idea for road engine that you want to last!
    Unless you are going to pull it apart, I'd go for the L0400 turbo. It needs a lot of mapping time to get spot on, which we are very capable of doing.
    Rick
  12. S3Alex
    10,589
    4,659
    Peak torque on mine is around 4000 rpm if I remember and pretty flat to over 6000.
  13. katenick
    katenick New Member
    17
    Where can I get a turbo and injectors from. ?
  14. S3Alex
    10,589
    4,659
    Depends on where you are in the country for who you'd choose.
    You need a good tuner who knows what he's doing as this isn't exactly a plug and play type of job.
    If it isn't done properly you can end up with a scrapped engine.
  15. RedDejavu
    RedDejavu Well-Known Member
    1,802
    333
    I'm considering going stage 3 next year. However only looking to get it up to 420-430. Is the Loba turbo going to be enough and fairly hassle free to fit? Will I need to upgrade dsg clutch too or only remap it?
  16. S3Alex
    10,589
    4,659
    The LO4xx would certainly get you that sort of power.
    It's a relatively easy fit compared to something like mine but as Rick says it needs careful mapping.
    The DSG will need mapping for the extra torque but generally you do not need an uprated clutch pack until you go beyond 440lbs torque
  17. RedDejavu
    1,802
    333
    Perfect is revo software capable to work with this type of turbo?
  18. S3Alex
    10,589
    4,659
    Best to contact Revo Kev for that.
    Revo Steve-W likes this.
  19. Revo Steve-W
    Revo Steve-W Well-Known Member
    615
    401
  20. Rick @ Unicorn Motor Dev.
    1,253
    586
    I can supply the turbo, injectors either second hand or get them from Audi/TPS.
    Rick
  21. katenick
    katenick New Member
    17
    great stuff. Can you pm me a price both new and second for turbo and injectors please. Plus is this turbo and injectors off another Audi model ?
  22. S3Alex
    10,589
    4,659
    The injectors are from the RS4..... Higher flow max than the S3 injectors although some are using Golf R injectors also.
    Loba turbos are very well made hybrid type turbos and offer a much higher flow than the stock turbo.
  23. Rob s3 stage 1
    Rob s3 stage 1 New Member
    10
    Hi
    What is roughly the cost of doing a stage 3 with all the parts etc...
  24. S3Alex
    10,589
    4,659
    Ok.
    Up to around 440lbs you don't need to uprate the internals so you would need the turbo plus injectors and software plus fitting etc.
    You could probably do this for around £4K or maybe a bit less but the APR kit is significantly more.
    Above that you need a lot more work including internals and you would be looking to at least double the costs to get to 500bhp.
    The costs then start to really go up.
    What I'd advise is working out what power you want and a budget first.
  25. Rob s3 stage 1
    10
    Cheers for getting back.
    I'm happy with around 350bhp
    Which shark say they do.
    I'm waiting for a quote from them.
    If I want that sort of power what do you think roughly I would need and what cost.
    Clutch. Fuel pump intake??
    Cheers.
  26. S3Alex
    10,589
    4,659
    No problems.
    You wouldn't have problems with the DSG box but would likely need a software revision and a manual clutch would give up.
    Fuel pump and CAI yes.
  27. Rob s3 stage 1
    10
    Cheers pal
    Appreciated
    S3Alex likes this.
  28. S3Alex
    10,589
    4,659
    Ahhh...just remembered....Shark's Stg 3 is equivalent to Revo Stg2+,i.e. HPFP,CAI and exhaust.
    They all call the same bhp/hardware /software requirements different things....LOL.
  29. Rob s3 stage 1
    10
    Thanks for the info mate
  30. Rob s3 stage 1
    10
    What is best revo 2+ or shark 3?
  31. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    Custom mapped 2+
  32. Rob s3 stage 1
    10
    I'm hearing shark stage 3 from others.
    It's confusing.
  33. Smirky
    Smirky Well-Known Member
    1,383
    447
    U can chuck superchips into the mix for what they call stage 3 stage 2+ really ,could also go down the tte420 route good for what 425hp?? Such a shame your so far north Rick !
  34. Rob s3 stage 1
    10
    Hi
    I'm happy with roughly 350 bhp which is what shark st 3 and revo st 2+ are.
    So hopefully just fuel pump clutch exhaust and intake needed for upgrade.
  35. Sayam
    2,703
    631
    If my understand of Revo/Shark maps is correct then how can it possibly be better to take a generic or half generic map over one written to your car from scratch by someone like @Rick @ Unicorn Motor Dev. or @Paul @ Unit 9 Remaps ?
  36. Samsellars
    Samsellars Member
    93
    22
    What are TTE like?
  37. S3Alex
    10,589
    4,659
    My own experience of this has been that the generic maps are good and can be tailored to some degree in terms of boost and timing etc but if you want something more to your requirements or more features then a custom map is the way to go.
    Before going completely off piste I was very keen on Revo software which had served me well for some time but the scope of what is offered by the likes of Rick et al is much wider and a completely configurable solution like the Syvecs is a step again on even that.
  38. Sayam
    2,703
    631
    Fair enough Alex..experience is greater than my shakey understanding lol.
    I just can't help but feel why would you want to be dictated to regards which parts you need for what stage by an external company..
  39. S3Alex
    10,589
    4,659
    Getting very good feedback from several forum members.
    Simon at TTE is someone I personally trust and know and there are several customers here you can ask.
  40. S3Alex
    10,589
    4,659
    It's more a matter of needing those parts such as HPFP,exhaust and intake regardless of which software you choose.
    A few will require you to use their own parts but that's easy to avoid.
