What's leaking now...2.5tdi Quattro?
mixmaster Jun 12, 2012
  1. mixmaster
    mixmaster Member
    86
    I noticed at the last oil change that I have a slight leak which looks like it's coming from between the engine and gearbox.
    I get a little patch under the car.
    What's it likely to be and is it an easy fix? I don't seem to be using any oil.
    Thanks in advance.
  2. marty.h
    marty.h Member
    124
    If its engine oil and coming from defo inside the bell housing on box will more then likely be the rear main oil seal. If its gear oil will be input shaft seal
  3. mixmaster
    mixmaster Member
    86
    Thanks. An easy fix?
  4. marty.h
    marty.h Member
    124
    Rear main will mean gearbox off and flywheel to replace seal
    Input shaft seal means gearbox off and not sure if the input shaft seal it a bolt on nose cone type or an internal seal worst case is box will need opening up to sort it
  5. Tom_B
    Tom_B Member
    296
    20
    Check that it's not hydraulic oil from the PAS
  6. Bradderz_1988
    3,947
    235
    ^^ as above all 3 could be your problem or even rocker cover gasket leaking down the rear and into the bell housing !
  7. aragorn
    18,161
    767
    what color is the oil?
    I'd expect engine oil on a TDI to be jet black, gear oil will be golden brown/reddy colored.
  8. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    367
    54
    Agree with that. Even after a recent oil change it doesn't take long to go black. What's the mileage and age?
  9. mixmaster
    mixmaster Member
    86
    It's a 1998 coming up on 200k.
  10. gedi
    gedi Member
    59
    what about sump gasket?
  11. spartacus68
    spartacus68 Active Member
    156
    34
    First thing to do would be to whip off the plastic sump guard, then get under the car for a closer inspection. Unusual for the sump gasket to go in my opinion.
  12. mixmaster
    mixmaster Member
    86
    I'm not losing engine oil but have noticed a drop in power-steering fluid so leaning towards this.
    However, why would that leak from round that area? What for and where should I be looking...
  13. mixmaster
    mixmaster Member
    86
    I forgot to quote this in my last post...
  14. aragorn
    18,161
    767
    PAS fluid usually leaks from the fittings on the cooler, or from the gaiters on the end of the rack.
    not sure how it would get inside the bellhousing though...
  15. mixmaster
    mixmaster Member
    86
    It might not be coming from inside the bell housing, just gathering around it then dripping from it.
  16. aragorn
    18,161
    767
    Stick your finger in one of the holes and see?
    My whole bellhousing was soaked in oil. Was pools of gear oil in the crevasses inside the housing.
