what would u do
johnyj Apr 2, 2008
  1. johnyj
    johnyj Member
    264
    have an oppotunity of getting a gsi chavalier for peanuts and was thinking of selling my 18ts
    then saving for something else maybe and dont shout an s3
    either that or sell cav on and get turbo for a4
    any suggestions??
  2. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    Get a turbo for the A4!! LOL
  3. PaulJC84
    PaulJC84 Owner
    2,890
    13
    If you prefer the S3 to the A4 save up for one.
  4. Broken Byzan
    13,237
    465
    I admit i have always had a soft spot for the GSi, But they rust like an Alfa !!
  5. johnyj
    johnyj Member
    264
    i like both the same really but s3 has stronger pistons and k04 already thats only reason
  6. johnyj
    johnyj Member
    264
    this one is j reg and only the normal rear arch rust
    got 17" alloys 2 are bent 100,000 miles but has 4x4 16v engine would b ok for a year of saving and could sell for same price as i got it
    looked on autotrader and these are goin 4 £1000 for a good one
  7. macca
    macca Member
    525
    sell a4, buy chavalier, save for s3, buy s3, turn chavalier into track day toy?
  8. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I would just buy a Mk2 golf as a run around while saving. They look cool as they are and should still be reasonably reliable.
  9. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    ADVERTISED for a grand,............but only the very good ones actually SELL for that ;)
    I'm a Vauxhall fan and spend most of my forum time on VXON etc, but I wouldn't touch another GSi with a barge-pole.
    I've owned several (and SRi's, Turbos, CDi's, GLi's, LS, TD, Diplomat etc etc etc), but the GSi with it's IRS suspension is a complete rust nightmare, hence i broke a few for parts.
    Underneath that big pretty plastic bodykit lies rust, rust, and MORE rust. The skirts act as a pair of water traps, and the chassis rails and spring seats have rotted through on most.
    Far harder to chase rust on these than on 'normal' Cavaliers that are without skirts and have the conventional rear beam.
    Then you'll have the hugely expensive 4X4 Transfer Box issues .........
    And then there's the floorpan...............
  10. hiltoa
    hiltoa VAG erfahren
    298
    Ditto that! ;)
    The only danger is that the Audi becomes the run-around while you get stuck into the Golf... :blush:
  11. Markey
    Markey Active Member
    2,175
    Thats also true :)
    Keep away from the vaux not worth it at all just save up for the S3 the normal way if you want, but remember half the money you would save for the S3 would turn your A4 into an easy S3 killer.
  12. johnyj
    johnyj Member
    264
    cheers for the warnings about the gsi dan ill have a look
    hes suspension has been changed to koni adj but will look at the rust issue.
    mk2 golf i take it u mean gti? not ganna motor around in 1.1l for a year..
    as for s3 cant stop thinking of a imola yellow one i saw on here (sigh)
  13. hiltoa
    hiltoa VAG erfahren
    298
    Definately a GTi, preferably a 16v ;).
    I reckon we'd let you off with a G60 though...
  14. johnyj
    johnyj Member
    264
  15. Dan Gliballs
    1,568
    Total nutcase LOL!!!
    I'll see you over on VXON then with your list of faults and questions :blownose:
  16. johnyj
    johnyj Member
    264
    got one already idles up and down from cold what have i done...
  17. Broken Byzan
    13,237
    465
  18. johnyj
    johnyj Member
    264
    just clean it out with carb cleaner like the a4?
  19. Broken Byzan
    13,237
    465
    Yes they do, i used to have this on my old cav. I did buy a new one in the end as they got cheaper, but a short term fix is to blast and soak in carb/brake cleaner or similar
  20. johnyj
    johnyj Member
    264
    cheers have been doing some research on my next purchase and have found the following:
    audi s3 good cond 1999 - 2002 around 7-8k but need either nogy blue or yellow v rare
    golf gti anniversary (180 bhp) 2002 around 7-8k black or silver is nice
    what you think?
  21. Dan Gliballs
    1,568
    The ICV on a C20XE engine is a complete penis to get to matey lol
  22. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    this brings back memories Dan, i loved and miss the tourqe of the GTE16V you just dont get that from a lazy V6
  23. johnyj
    johnyj Member
    264
    is it not on the top near the throttle body?
  24. Dan Gliballs
    1,568
    Nope, it's under the inlet manifold at the back.
    It's more accessible on the later X20XEV (Ecotec) engine.
  25. Dan Gliballs
    1,568
    I found the lump in my GTE to be fairly torquey ;)
  26. rasA4
    3,287
    119
    nice does yours leak oil? after driving it?
  27. johnyj
    johnyj Member
    264
    its the non porus one does that make a difference?
