What will happen if I disconnect my battery?
abimogen Feb 20, 2011
  1. abimogen
    abimogen New Member
    10
    Bit of a silly question I know, but what will happen?
    I've just got the car and dont have a radio code or anything. Bit worried about the throttle body re-adapting correctly. Should I be concerned about anything else?
  2. neilA4
    neilA4 Member
    210
    you will have to put code in for the radio, think you can disable the code with vagcom before disconecting battery. Nothing else to worry about.
  3. abimogen
    abimogen New Member
    10
    Thanks.
    I have Vagcom lite, can I do it through that?
    Sorry, also forgot to say its a 98 1.8 n/a 20v, if that makes a difference.
  4. hades-
    9,480
    646
    it wont start ?
  5. abimogen
    abimogen New Member
    10
    Yeah, ok. Left myself open for that one!!
  6. hades-
    9,480
    646
    if you have remote keys you will have to match them back to work
    your 1 touch windows will need resetting
    radio maybe maybe not
    clock date etc resetting
    think thats about it
    why do u need to disconnect battery
  7. abimogen
    abimogen New Member
    10
    How do I re-match the keys (actually only have one) and the windows?
    I just want to make sure the drain holes underneath it are clear.
  8. hades-
    9,480
    646
    for the windows you press and hold down till open and still hold for a few secs
    then the same close them keep hold for a few secs
    if you have remoce central locking put key in ignition turn on press lock unlock
    turn off shut door lock with button
  9. hades-
    9,480
    646
    quick way to check look if no puddle of water should be ok
    or pour bucket of water in and watch under car if it drains its ok
  10. neilA4
    neilA4 Member
    210
    can't find the radio coding options now, may have been a different radio! will keep looking.......
  11. aragorn
    17,960
    702
    Ive had my battery off a few times and the only thing I had to do after was reset the one touch windows.
    Radio just said LEARN then started working, remote fobs were fine etc.
  12. aragorn
    17,960
    702
  13. abimogen
    abimogen New Member
    10
    All done. No probs at all, radio just came on as normal, didnt actually try windows, remote fine and throttle body made a squealing sound for about 10secs.
    Drain hole blocked solid, tray full of water! I thought hole was a grommet for a second.
    Thanks to everyone for their input!
  14. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    "What will happen if I disconnect my battery?"
    The World will end....
