What were Audi thinking with the Speedometer on Audi S3...
Leo-RS May 10, 2014
  1. Leo-RS
    Leo-RS Well-Known Member
    479
    343
    Why does the UK Audi S3 have clocks that run upto 160mph but yet European Audi S3' run upto 186mph? That's quite a significant difference and surely a design flaw for UK spec cars?
    The top speed is governed by a limiter at 155mph but this is not a speedo indicated 155mph, it's usually a GPS 155mph limiter which means the clocks will easily run past 160mph before hitting the limiter. For example, look at the acceleration video below, this car hitting the limiter at 266kmh (165mph speedo) The 1.6tdi has a 160mph clock, seems nuts that the S3 has the same, for those of us that like tuning, we are going to go way way off the standard clocks. Very lazy by Audi UK
    AUDI S3 8V ACCELERATION 0-266km/h TOP SPEED - YouTube
  2. The Challinor
    The Challinor Well-Known Member Audi S3
    4,554
    1,227
    I presume if it's de restricted then the traditional clock needle will stop at 160 and the digital speedo will continue to increase.
  3. illingworth22
    illingworth22 Active Member TeamMisano Audi S3 Audi A3
    476
    152
    43
    300 KPH here in Ireland
  4. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,389
    1,917
    Maybe because you have a speed limit of 70mph in the UK? :uhm: Just trying to put myself into the head of an Audi exec..
  5. pat15312
    pat15312 Well-Known Member
    530
    252
    Send in a letter and I'm sure Audi UK will get right onto it...
    steeve likes this.
  6. vivalacoulter
    vivalacoulter Active Member VCDS Map User Audi S5
    409
    61
    My 12 year old S3 laughs in the face of 160mph clocks...[​IMG]
    Foshiznik likes this.
  7. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    I've had mine off the clock loads of times. The digital speado keeps going (up to 171 mph so far!)
    rams_s3 likes this.
  8. Leo-RS
    479
    343
    Haha, and redesign the clocks based on my complaint.
    It's something that I think Audi have overlooked or is clearly a cost cutting measure when converting from its native euro to Brit config, if the Euro cars have 186mph clocks, why dont we? 186 - 160 is quite a significant difference. The old Audi S3 dash above runs to 170 ffs.
    As for the 70mph limit haha, why not just put limiters on the car set at 70 then :p
    It's just an annoyance I suppose but I guess the dash also reads digitally so not a big issue, but a design flaw non the less. Hey maybe if we do complain, the MY16 will see a re-designed 180/200 clock face? You never know ;)
  9. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,763
    It's to give us better granularity for more of the scale, before it changes to the smaller scale on the speedo.
  10. Vertigo1
    Vertigo1 Well-Known Member
    3,706
    782
    There's another odd difference.
    The UK dial has two different "zones" - it's linear up to 100mph, then the scale doubles beyond that - so the same arc that would be a 10mph increment below 100mph is a 20mph increment above it.
    On the European dial pictured above there are far more zones or scales on the dial. 10-70kmh appears to be one zone, then 70-100 is another, then after 100 it gradually changes, with each 40kmh increment being a slightly smaller arc than the previous one. It's all over the place!
  11. Flibble
    Flibble Active Member Team Estoril
    544
    142
    43
    IIRC it's three zones: 0-30, 30-100, 100-160. Pretty sure the bottom 30 mph is much larger than the next 30 mph anyway!
  12. RossR
    RossR Active Member
    501
    122
    43
    The different zones are partly for the adaptive cruise control. Towards the bottom of the scale you can change the set speed in 2.5mph increments, but above 40mph it is 5mph increments. You can't set it to over 100 mph. These are all indicated by LEDs at constant spacing.
    On a road with a speed limit you won't be going over 160 mph indicated unless you are looking for some free accommodation for a few years. If you're doing some top speed testing on a de-restricted autobahn then you can turn on the digital speedo for more precision (but not accuracy). I can't think of a situation on a track where you would need to know your speed so precisely at the top end - and if you do the speedo isn't going to be very accurate anyway.
  13. Leo-RS
    479
    343
    To be fair, that is a silly analogy. Why have a speedo that runs above 70 then, or indeed 100 if that's the speed you lose your license at?
    For a 300bhp S3 to have the same 160mph dash reading as the bog standard base model is lazy by Audi, especially when the top speed surpasses the maximum range on the clock. (You'll hit the 155 limiter north of 160) The old S3 had a 170mph clock, the new S3 in Europe has a 300km/h (186mph) clock. Why has the UK been missed out here?
    It is nothing short of laziness from Audi UK when they converted from EU to GB spec. The clocks should read minimum 180 but probably more like 200 same as existing RS3 model. This is the first car I've ever come across when the top speed of car, even limited surpasses the design of the clocks.
    You can go faster than 160 in the UK at race events such as 30-130 / Vmax typed events. Why should we have to ''just do'' with the 160mph clock because we have a 70mph limit. That's a ludicrous statement. Yes, you can still use the digital but that is not the point. This is clearly a design flaw and very lazy from Audi UK to not have noticed this.
  14. veeeight
    6,849
    4,763
    Take direct action.
    Write to Audi UK and express your indignation.
    Wondering Soul likes this.
  15. RossR
    RossR Active Member
    501
    122
    43
    I don't think I used an analogy, silly or otherwise.
    Surely if you are doing a Vmax type event you wouldn't rely on the stock speedo?
    Don't let me stop you taking this up with Audi though.
  16. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    As the UK is one of a very few territories running MPH maybe they made a decision to run a single set of clock templates for MPH cars and reduce costs???
    To be honest given where the TT clocks have gone I think that many of the new Audi's will be leaving tradtional analogue clocks behind in future generations.
    In the meantime I'll leave you with an image of the clocks in the 8P that offer a 190mph maximum speed (although I can attest from a trip to Germany it doesn't get close).
    You don't think it was to make the clocks easier to read?????
    chrisboyle999 likes this.
  17. chrisboyle999
    chrisboyle999 Member
    33
    10
    Exactly. It'll be a bean counter input. More likely so as not to incur increased cost rather than to reduce it.
  18. The Challinor
    4,554
    1,227
    Anyone heard of a way to de-restirict without invalidating the warranty? Not via Stage 1 route, just de-restrict.
  19. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,718
    1,561
    Am I bovvered?
  20. Tristan2
    Tristan2 Well-Known Member Team Nardo Bronze Supporter Audi RS3 quattro saloon DSG
    424
    353
    So what is the top speed with the limiter taken off?
  21. NATOuk
    NATOuk Active Member
    133
    31
    That's not true I'm afraid, I can adjust my adaptive cruise control +/- 2.5MPH at all points on the speedo (above the minimum around 20MPH of course). Haven't tested the upper end mind you, but it definitely goes to at least 100MPH.
  22. RossR
    RossR Active Member
    501
    122
    43
    Well it must have been revised because mine has different increments across the range. My car was manufactured in July or August 2013.
  23. NATOuk
    133
    31
    Yeah, looks like it, mine's July 2015, they must have tweaked the setup of the ACC.
  24. PhatGit
    PhatGit Active Member
    140
    73
    Am I the only one the finds the bottom segment really annoying? It mainly because I keep misreading it and driving at 35 instead of 40 (way too many speed cameras around here!)
  25. NATOuk
    133
    31
    I actually really like it! I got used to it very quickly, but obviously it's personal preference
  26. PhatGit
    140
    73
    It's been 14 months, and I'm still not use to it. Will probably click with me on the way to trade it in !
  27. veeeight
    6,849
    4,763
    Yes, early cars had the choice of standard ACC, and enhanced ACC, which went to a higher speed.
  28. glospete
    glospete Well-Known Member Team Glacier Team Ibis TFSI Owners Group Audi A3 S-line owners group Audi TT
    1,571
    1,071
    124mph if I recall correctly.
  29. terminator x
    terminator x Well-Known Member Team Nardo Audi RS3 DSG
    2,273
    2,378
    RS3 has 180 on the clock ;)
    TX.
  30. thebluefox
    thebluefox Active Member Team Sepang Audi S3
    382
    246
    43
    I do the same thing when the satnav is on. Ususally I use the digital speedo - when the Nav is on the DIS though I'm always getting confused between 0 and 40!
  31. /dev/null
    /dev/null Active Member
    222
    45
    Does it really matter? If you're doing over 160mph then the last thing you should be doing is staring at your speedo.
    G-S3 likes this.
