what tyres to buy
amoffat Feb 20, 2003
  1. amoffat
    amoffat Member
    466
    Nigel,
    How was the quality of the installation? I mean, normally these guys have to take your car apart to install wiring etc. Was everything put back as good as new? No screwdriver marks etc?
    I am always afraid that squeaks and rattles start when I I've had 3rd parties removing trim in the past.
    Scott
  2. Guest
    Not driven the car since. The ijnstallation was good - no marks, everything back in the right place.
  3. Guest
    Cleared one thing up - they now supply T-mobile SIMs free, other networks cost £18. I can live with it being on T-mobile and just top up using the card.
    Other thing not cleared up is that the installer said only the Advance can notify you of the alarm going off; however, the manual (just looked) says there is an optional (have to request) wiring loom, which does enable this for the standard device! Have got calls into them to find out if I have to drag 'em back to fit the other loom!
  4. Guest
    Nige
    Your Trackm8 should have been supplied with the standard 4 wire wiring loom - mine was. I fitted my TrackM8 myself can't tell you where though /ubbthreads/images/graemlins/wink.gif.
    Very impressed with TrackM8
  5. Guest
    re: Trakm8 wiring looms - advance v standard for alarm notification.
    Interactive Projects' responce was as follows, when I questioned them about this.
    [ QUOTE ]
    TrakM8 1.1 Standard does support the alarm feature. You will need the
    11-wire loom. You should be able to order this from the company that
    supplied your trakm8, you will probably need to arrange for the installer to
    come and fit it. There are a few things that may stop you being able to use
    this feature:
    1. The alarm must have an external output to notify the TrakM8 when the
    alarm is sounding. Some alarms work though the vehicles internal network,
    TrakM8 will not work with these alarms.
    2. The external output must either, go high and stay high, or go low and
    stay low, for the duration of the alarm. If the line is pulsed, you will
    receive alot of text messages. Some alarms allow you to configure the
    behaviour of the external output.
    [/ QUOTE ]
    Am just about to phone up TTL and ask why do they not tell people this, when they order - would save them having to come back and enable it with the other loom!!! arrrghhhh.
  6. katanwara
    katanwara New Member
    15
    soon ill be required to replace the tyres on my car alloys,
    just wanted to know whether there was any particular brand
    i should go for. I guess a hard wearing brand would be nice,
    a nice look too it always is an extra. /ubbthreads/images/graemlins/smile.gif
  7. rickparmar
    rickparmar va va voom
    2,272
    ive got Avon ZZ3 nice tyres
  8. Mike.M
    Mike.M Well-Known Member
    2,508
    169
    How do you find the ZZ3's as I know the ZZ1's are supposed to be **** in terms of grip due to being so hard.
  9. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    From what I've read, Goodyear Eagle F1 GS-D3's seem to be one of the best performance wise... not sure how hard wearing they are but they supposedly stick like glue!
    And they have the sexiest tread pattern!
  10. Grant
    1,206
    118
    Avon ZZ3 - £94.20
    Goodyear Eagle F1 GS-D3 - £117.90
    both 225/40/18 and prices from mytyres.co.uk
  11. dunk
    dunk Member
    770
    common preferred tyres include:
    goodyear f1
    bridgestone so3
    toyo proxes s1
    pirelli p zero nero
    there are many others but these tend to be some of the best performing at the expense of wear- these ones are also particularly good when it gets wet as well where as the pirelli rosso and p7000 tend to be a lot worse in the wet.
    try ebay for price though - i just bought 235/40/18 pirelli pzero nero for £87 each including vat and delivery (i bought 6, i couldnt resist, these are 3% over on the rolling radius but thats not a lot) - my local tyre place wants £10 to fit and balance per tyre.
    duncan
  12. FrOgR
    FrOgR Member
    72
    I've been consiodering Proxes next time whats peeps thoughts on these?
  13. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    A wise choice! /ubbthreads/images/graemlins/grin.gif
  14. paultaylor
    paultaylor Member
    294
    Pirelli P-Zero Rosso 225/40 18s compound 92y, wore the first set down to slicks and amazingly they still worked in the wet, have a new set on now for the last 1000 miles, the car is almost boring it's so composed, the knocked five seconds off the wet handling circuit time in last years Autocar tyre test using a M3 as the performance test car on Rossos, the Continentlal Conti Sport were only three seconds slower, this was at Michelin's own testing track and it's a short lap too, 42/43 seconds, you should see the photo of the michelin engineers, they look like they're about to cry.
    Paul
    Black 02 S3 225, sadly no mods yet due to lack of cash, but soon!
  15. Jonc
    Jonc Member
    71
    I've had Yokohama A539s, very grippy in the dry, OK in the wet, currently have Falken FK451, also grip quite well in the dry and in the wet, noise levels are slightly higher possibly due to stiffer side walls. The Japanese brand tyres are comparible, if not on some occasions, perform better that the big premium brands, and are usually loads more cheaper.
  16. Markb
    Markb Active Member
    2,139
    Tried loads of different ones, but found the Good Year F1's to be the ones I prefer.
  17. MingBluS3
    MingBluS3 Member
    360
    I'm using Michelin Ps2's they are superb in the dry good in the wet but wear fast, especially the edges.
