What turbo support for BTs etc
s3dave Mar 12, 2013
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    As title what do you guys use with the BTs etc?...or do you not bother? the ko4 as a mounting ring for the bracket on the hotside
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    I haven't made anything for mine, athough I do keep thinking about doing so?
    Suppose it all depends on the strength of the mani
    I had wondered if it could also put strain on the mani when it expands although it will be minimal?
  3. s3dave
    10,110
    736
    There is the weight of the downpipe too..
  4. <tuffty/>
    20,900
    3,710
    Don't normally bother... stainless steel manifolds move all over the place.. yo would have to make the support move with everything too else its more likely to add to the problem than provide a solution..
    Mine just hangs off the mani... Stacey, yours will be man enough as it is ;P
    StaceyS3 likes this.
  5. StaceyS3
    2,489
    473
    The TSR does feel pretty manly by the fact it weighs as much as a cast mani ;)
  6. Sam_
    Sam_ Down under
    3,035
    480
    Yeah you'd expect the TSR manifold to cope for that kind of money...
    I remember the cossies use supports that hang the turbo using rose joints to allow it to move somewhat.
  7. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Mani supports my turbo: :icon_thumright:
  8. superkarl
    superkarl MAN OF STEEL
    9,405
    2,379
    im not using one either.
    i think its more appropriate for tubular steel manis rather than cast.
  9. badger5
    9,404
    1,944
    if you are contemplating the relentless tubular, then a support is mandatory.. I welded a lug to the 2871(cn) thing of samb and lightly rebent the stock k04 support bracket to pickup off it.
  10. s3dave
    10,110
    736
    Cheers bill yes it will be a relentless v3, i thought so, ive already put a bracket on it to pick up the origonal support
