What to use to remove wax?
Markb Jun 15, 2004
  1. Markb
    Markb Active Member
    2,139
    As subject I've given my car the full 3 stage Meguiars treatment, but I've managed to lock some tar spots under the polish and it's starting to bug me /ubbthreads/images/graemlins/frown.gif
    How do I go about removing the polish that I've put on?
    As I think I am going to use the deep body scrub on it to remove it completly. Then re-apply the 3 stage kit.
    Cheers in advance /ubbthreads/images/graemlins/beerchug.gif
  2. Markb
    Markb Active Member
    2,139
    Hmm not sure if it will or not.
    I've heard people talk about a de-waxer/greaser solution. Anyone know of the proper product?
  3. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    paul_brad said:
    Can you not just use meths? (me=amateur)
    [/ QUOTE ]
    I would have thought not.
  4. Markb
    Markb Active Member
    2,139
    Someone must know as body shops use it when they come to prep or spray body panels.
  5. jojo
    28,995
    3,640
    wet and sand
  6. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    go to halford/motorist center .etc and get some tar removing spray...that'll shift it.
    Rich
  7. jgrand
    jgrand Member
    147
    Or Meguiars Bug & Tar Remover?
  8. ultrasporta4vk05
    ultrasporta4vk05 Member
    30
    try dishwashing soap... that removes the wax at least but not sure about the polish
  9. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Turtle Wax Bug & Tar Remover
  10. wigginer
    wigginer Member
    425
    Hi ImolaS4,
    Is there a technique to prevent the claybar smearing? I use Meguair's Quik Detailer to lubricate, but it always tends to smear. /ubbthreads/images/graemlins/confused.gif
  11. ImolaS4
    ImolaS4 Member
    275
    Not sure what you mean exactly by "smear". But....
    First make sure you're not putting down any pressure - just the weight of the bar. And keep rotating the bar by re-molding it and folding the dirt into the inside of the bar. Only a small section requires me to remold. It's time consuming, but I don't want to leave any hairline scratches just because I was impatient.
    I use an equivalent detailer spray for lube so I don't think it's the Meg. Q-D. I've used distilled water as an alternative. I know... they say not to use water, but distilled water worked for me, too.
  12. wigginer
    wigginer Member
    425
    I must be using an inferior claybar. The one I purchased from Maguiar's was very small (approx 2"x3") and hardly worth it. I get the impression you are using something a bit bigger ...
    fyi
    English Dictionary interpretation of the word 'Smear'
    1. to spread (something sticky or oily) thickly over (a surface).
    2. to make or become blurred; to smudge.
    The one word says it all! .. and that's the beauty of the English language ... /ubbthreads/images/graemlins/beerchug.gif
