What to use to remove spray adhesive glue?
Markb Aug 17, 2004
  1. Markb
    Markb Active Member
    2,139
    As subject I've bought a head lining from a scrap yard out of an A3 and I am hoping to use the material to cover something else /ubbthreads/images/graemlins/wink.gif
    The only problem is that it's got foam backing that has been stuck to it buy strong adhesive.
    Any ideas what I can use to dissolve the glue and remove the foam backing?
    I know it's an odd one LOL
    Cheers Mark
  2. CARACTERE007
    CARACTERE007 Member
    319
    wd40 is realy good at removing sticky stuff
  3. imported_Robbyc
    imported_Robbyc Guest
    There is some stuff called tardis which i have used in the past to remove glue. you might need to go to a valeters for that, bit of a pain but its good stuff.
  4. cheechy
    cheechy Member
    96
    Or Lakeland do something called Sticky stuff remover. Smells of orange and works quite well at disolving sticky stuff /ubbthreads/images/graemlins/smile.gif
    Don't know how effective it would be in your case though /ubbthreads/images/graemlins/confused.gif
  5. Add7
    Add7 Member
    310
    use lable remover from RS component or ard electronics?
    Really good and cheap?
  6. At work we use nail polish remover to remove glue/labels and permanent marker. Its cheap and easy to get, The girlfriend/wife will have some.
    Cheers,
    h1.
  7. Markb
    Markb Active Member
    2,139
    Hmm I may have a go at the nail polish remover, but I am not sure it will work.
  8. Add7
    Add7 Member
    310
