what to use tensioner kits
s3gazz Oct 2, 2012
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    hi all a quicky what tensioner kit would u use if u was doing an engine build..
    INA manual tenstioner kit or standered tensioner kit also do i replace the lot dampers all of it as my engine is in the car or just get a new tensioner thanks.
  2. <tuffty/>
    20,847
    3,687
    Std tensioner is fine for your power level/setup... manual tensioners are mainly for when you have uprated valve springs and cams...
  3. s3gazz
    1,376
    99
    thamks tuffty ill just buy one from gfs the thanks do u no if the pin comes with this
  4. <tuffty/>
    20,847
    3,687
    Yes they do... don't pull it until you are sure... always double check the belt as they have a habit of ending up a tooth out...
  5. s3gazz
    1,376
    99
    Ye thanks ill make shore first tuffty
  6. Prawn
    11,369
    3,232
    Yup, mine ended up a tooth out after I fitted a new belt, Paul said to check it, and if I'm completely honest, I almost didn't bother as I was 100% confident it hadn't moved whilst I swapped the belts over.
    Trusting Pauls knowledge, i decided to humour him and spin it over once to check timing, and bugger me, it was a tooth out!
    Standard hydraulic tensioner on mine too Gaz.
    The INA manual tensioners are a rip off anyway, they're just a standard hydro one with the insides removed and replaced with a bolt!
  7. s3gazz
    1,376
    99
    Thanks prawn I new it was a rip but said I needed it so said no ill buy the rest of the kit tho Wich I'm buying tonight rods and That maybe get back on the road then ha.
    gfs I'm getting mine £35 they want pal
