What to remove to change aux belt and tensioner
adidasandy Feb 17, 2012
  1. adidasandy
    adidasandy Member
    271
    As above, my belt is squeeling and is in poor condition so going to replace both belt and tensioner.
    Looking at the job (S4 B5 2.7) it looks like bumper, lights, slam panel to be removed and rads pulled forward. Is this correct?
    Andy
  2. audiv8quattro
    audiv8quattro Member
    443
    9
    When I did my belt I just put it in service mode didnt bother removing lights ect just removed bumper and pulled everything else forward, look in the technical how to post in this section, I think there's a guide in there.
  3. aragorn
    18,544
    865
    Bumper off.
    Unbolt bumper shocks and replace one bolt each side with a long piece of M8 threaded bar (~12" each side).
    Unbolt top corners of from panel and then pull the entire front panel forward.
    You'll only get about 6 inches, but its enough to get into the belt and do the required.
  4. adidasandy
    adidasandy Member
    271
    Thanks fella's, sounds good to me.
    Andy
  5. B5 BIKER
    B5 BIKER Member
    266
    Don't know about yours, but on the tdi it pays to replace the pulley on the
    alternator at the same time.
    They have a tendancy to give trouble on the vag tdi engines
