What to look for?
stu_m Jul 25, 2012
  1. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    I'm off to look at a 05 2.0tdi avant later for my brother
    Is there anything I should look out for? I have full vcds so will do a full scan
  2. Wrath
    Wrath Well-Known Member
    1,196
    41
    Yeah, forget it. Unless it's had a the oil balancer shaft changed to a gear driven one (I doubt it) then run away. To be honest, even if it's been done I would ask who did the work.
  3. stu_m
    1,440
    They can't be that bad there's plenty of them still running round?
    What's the cost of parts if it hasn't been done?
  4. Wrath
    1,196
    41
    From 2k upwards but if it blows then it's a new engine and turbo. I really wouldn't go for it. Go for a 56 plate onwards if you have to (although they still have problems just not as twofold as the 05 ones) or go for a 1.9.
  5. stu_m
    1,440
    2k for parts? thats almost a new engine!!
    Its not me who is buying it all I can do is pass on the advice and check the car out it may have been done already it my not i will check it all out and give my opinion
    I have always told him to get the 1.9 its the same as what I have in my B6
  6. Paul B7
    Paul B7 Active Member
    622
    34
    Wraths advice is sound and solid.
    Cost for my own repair was £2053.60p and that was heavily discounted by Audi.
  7. stu_m
    1,440
    So that's 2k from audi with labour?
    So probably about 700 in parts? The car is cheap enough to buy and do the work if it all checks out ok! We do our own work on cars too so labour is not an issue
  8. Paul B7
    622
    34
    The price I paid was at Audi Teesside in December 2011 and included a 20% discount off parts and 50% off labour.
    I also had the water pump and timing belt replaced in the same bill.
    Cost for the Balance Shaft/oil Pump assy was circa £1100 alone.
  9. scottshere
    scottshere Member
    369
    I too have been looking at changing from my B6 to a B7
    Looking to change to an Avant and thought of getting something newer than my 53 plate
    I hear/read the balance shaft is a problem right up to 2008 if im not wrong
    Not too many of the 1.9 kicking around either
