what to look for in a privately sold car?
audi_driver Apr 1, 2009
  1. audi_driver
    audi_driver S LINE
    147
    My girlfriend wants to buy an audi a3 from this guy but we havent got experience in buying from a private seller. What kind of questions should I ask him/look for? He told us there was a leak in the boot! Its a 57 plate 1.6 special edition for £11 grand, is that worth it? Thanks guys
  2. allazey
    allazey Guest
    A quick google of 'questions to ask when buying a used car' will give you loads of sites with the best 10 or so questions to ask.
    The leaky boot sounds dodgy. If it's a worn seal then thats quite easily sorted. Although I would have a good look inside to boot to see if any rust/damage has developed because of the leak.
    The other cause of the leak could be a lot more serious. Maybe the car has been in an accident? And now the boot doesn't line up properly. Before I bought my A3 I went to see one that had the same problem. On closer inspection I noticed that the welding on one side of the boot was not original (accident repair). Then noticed bubbling under the paint (rust) and that the boot didn't open/shut as smooth as it should. I walked away.
    As for the value of the car, you can do a free Glass's valuation to find out the various values, using this link http://www.theaa.com/cbg/Manufactur...trade=&journey=fullValuation&manufacturerCode=
  3. audi_driver
    audi_driver S LINE
    147
    Thanks for the help, ill be sure to check what caused the leak at the back of the boot. He told me he was getting that fixed at the dealers before he sell it off, maybe I can phone in at the garage to see what caused it.
  4. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    Has it ever been stolen / recovered?
    Has it ever been in a minor or major accident?
    Can I see the receipt, service history and bills please?
    Have you ever modified the vehicle in any way (suggest you need to inform your insurers if this is so)?
    Check the mileage intervals between services (dates and miles to see what kind of usage the car has had - short service intervals indicate its used for company mileage)?
    Has it been garaged during its life?
    Why is he /she selling the car? (they can tell you anything they like, but their response can often guide you to an answer) - if they are upgrading it is likely there is nothing wrong with the car, if they are changing for an 09 plate then ditto. If they are changing like for like be more suspicious.
    Has the car had any repetitive service related issues (if you suspect anything note the servicing dealer name and then phone them independently to say you are looking at buying this car, and do they hve any history of warranty work or expensive repairs they can share with you) - some may say this is a back handed approach, but if it is an expensive car then you need to protect yourself.
    How much warranty is left on the vehicle?
    How much tax is left on the vehicle?
    When would the car be due an MOT (if appropriate)?
    Then
    • Check the shut-lines of the body panels of the car to make sure it all looks straight
    • Check the VIN plate in the window (passenger side) matches the V5
    • Pull back the carpets in the boot and check for irregular welding / overspray (paint), or anything that indicates a heavy rear impact
    • Check the boot opens and closes correctly and that all the rear lights are working as you'd expect (take 2 people to confirm this)
    • Check all the doors open and close smoothly and w/o sticking or effort to reclose
    • Check the oil filler cap for white residue (potential head gasket or sign of lots of short journeys)
    • Check the under bonnet condition - does it look right for a car of its age (too clean can be as much of a concern as too dirty if it is inconsisitent with the cleaning standards of the rest of the car)
    • Turn on the car and make sure it: starts first time / there are no warning lights on the dash / that the idle sounds fairly consistent / blip the throttle lightly to make sure the idle returns to the normal level without excessive hesitation
    • Check all the electrical switches work (inc. radio), switch a load of electrics on at once to see if the headlights dim excessively (sign of worn battery / alternator). If there is a trip computer make sure it works and that all the menus work. Read the fuel figures on the trip gauges as they will give you a sneaky peak as to how the car has been driven (if they haven't reset it)
    • Put tyres on full lock and check for inconsistent wear across the tyre profiles
    • Push down on each corner of the car to ensure the springs & dampers are working efficiently (if car bounces more than once before returning to position they could be on the way out - if so are there any leaks on the dampers)
    • See if you can conduct a visual check of brake pads. If they aren't visible due to wheel type, run your finger across the brake disc to see if they are OK (not heavily ridged or warped) - ONLY DO THIS WHEN THE CAR IS COLD OR YOU'LL TAKE THE SKIN OFF YOUR FINGER TIP!!
    • Get someone to check the exhaust round the back when the car is running in case of any (blue smoke / blowing / excess smoke)
    • Take a magnet with you, and put it inside a microfibre cloth, then run it along any suspect panels for signs of filler - magnet wont stick obviously!!!
    • Use one of the mobile phone checkers to ensure the info matches their descriptions (like this LINK)
    Nothing else comes to mind at present, but others on here will know of current issues to check (maybe things like knocking wheel bearings on a test drive).
  5. WiZBiT
    WiZBiT Member
    437
    Let me just print that badboy out ;)
  6. anton2015
    anton2015 Member
    178
    Ill give you a thanks too
  7. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    f- in hell warron did you have this saved you didnt type this all out did you ... well done though you hit the nail on the head lol
