What to look for if you keep blowing coils
Welly Jan 13, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Thought I would share my painful and lengthy experience with you all. (Sorry about the over sized images here.....)
    Has an issue so annoying it had it's own name and theme music. "The phantom misfire". Anyway, long story short, it was with the APY bolt down pencil coils.
    Had a misfire, changed plugs. Went away. Came back 2 days later. Changed coils. Came back 2 days later on cyl 3 after blowing the coil....
    This went on and on until I'd eaten 3 coils and decided that something else was wrong. One dodgy coil out of the box isn't unusual. 2 in co-incidence and 3, well no way pedro.
    A bit of hunting and advice led me, eventually, to the coil wiring loom. Had a glance, strapped up as usual.... Untill I ripped it all off anyway
    After an hour of stripping electrical tape back, this is what I encountered...
    As you can see, that wiring is pretty poorly. We strapped it all up with heat shrink for the time being but I am planning to change this part of the loom out in the near future.
    Still, many days now without any problems suggests to be that this was the issue. There was visable scorching inside of the heat blanket around the cyl 3 area, indicating a short across the wires.
    I believe the part number for the replacment to be 1J0-971-658-L. The heat blanket is 8L9-121-659.
    For anyone having this problem, and interested in changing this part of the loom out rather than repairing, this link may be useful.
    http://forums.vwvortex.com/zerothread?id=2597240.
  2. Broken Byzan
    13,237
    465
    Nice one, glad you found it. I t seems the norm for the loom to crack there, possibly due to heat
  3. Welly
    10,696
    128
    Yep, I would assume thats the case. Heat and age. We all crack the same way with both!
  4. <tuffty/>
    21,256
    3,880
    Had the same on mine... taped it up and reloomed it all...
  5. jojo
    28,899
    3,553
    Hmm, I should have a look at mine sometime then, since it's over 10 years old now!
  6. Nilz
    11,353
    894
    Nice one Welly, glad you getting it sorted, looks like it will be a bargain buy after all, once all the little bits are done ;)
  7. 1animal1
    9,978
    yup ive had to re-solder one of these already.....may strip it away in the summer, thats looks terrible!!
  8. Welly
    10,696
    128
    Fingers crossed....
  9. jonny87
    jonny87 Active Member
    1,094
    nice one dude!
    i know the coils aint cheap so this could be a good preventative measure for everyone here, i for one will certainly be inspecting this once it warms up :)
  10. Effect
    Effect Member
    469
    how do you get fresh heatsrhrink onto wires that are connected at both ends ?
  11. Welly
    10,696
    128
    Cut, sleeve heat shrink, solder wire and heat shrink over the top.
  12. Prawn
    11,532
    3,471
    if one were to replace the loom going to the coilpacks, where would it join into the rest of the engine loom?
    Mine's just started doing exactly this, I first suspected plugs, but after changing for brand new plugs tonight it's worse! Having disturbed all the coilpack wires in changing the plugs, I'm sure this must be the issue.
  13. Welly
    10,696
    128
    Hard to say mate to be fair. Depends on how far back the damage goes. This is generally caused by rocker cover heat, and the plastic cooling and warming regularly. However, was talking to badger5 about it when there the other day, and Bill said that he has found this part of the loom damaged a lot further back...
    So..... suck it and see really. Start by stripping the loom back and have a look. Getting it back to the N75 plug is easy enough. Review what the loom is like up until that point and go from there.
  14. Prawn
    11,532
    3,471
    Cheers man, I've been so lucky with the car up until now I feel, 200k and it's not no 'nasty' problems, everything that's broken has been pretty black and white, like the diff falling out :p
    Really hoping this wiring is the cause of my current issue. given it's relation to moving the coil packs I'm thinking it must be.
  15. Prawn
    11,532
    3,471
    After further research this mroning, I've found the problem isn't there when cold, when the car started to warm up a tad i booted it and it was absolutely fine.
    When up to temperature it still seemed OK, but after 30 mins when everything had had time to heat through, the misfire was back again. Seemingly rather intermittent.
    I'm going to call audi today about a loom.
  16. Welly
    10,696
    128
    Sounds familiar! Mine just did it when it fancied doing it. Normally when racing something just to **** me off!!
    Also, swearing at the car, and talking about it behind it's back will only make it worse.... :(
  17. Welly
    10,696
    128
  18. Welly
    10,696
    128
  19. jonny87
    1,094
    prawn: i asked audi about a replacement coilpack loom for the s3 and the answer was they only do the seperate loom for the denzels, for our petrol cars we have to buy the whole loom (well the passenger half of the ecu loom anyway) and as welly says that would cost mega bucks, the ones in the states are only like £30
    am thinking if there are a few of us needing this loom, might aswell order all together?
  20. Prawn
    11,532
    3,471
    Cheers for the advice Jonny, I too called Audi yesterday, who said all they can offer me is some coil pack connectors and a pack of new wire to solder it up myself, or a full engine loom at around £550. **** that.
    As for ordering from the states, you guys go ahead and do it, but it'll be of no use to me!
    Having a 98 AGU A3 it's rather different to the S3 setup, I think my coilpacks only have 3 wires to them for a start.
  21. Welly
    10,696
    128
    Dude, didn't realise you had an AGU although I should of from threads previous....
    Anyway, are you sure it's a loom issue? I mean, have you SEEN the cracks?
    On the AGU, as opposed to every other engine, there is an N122 Final output stage chip which controls firing. On all the other engines, the final output stage is built into all the coils individually, except the AGU. This is the main reason why the AGU has very few problems with coil packs going bang.
    They aren't easy to get hold of, but if you know someone else with an AGU engine, or can find one being broken, deffo worth a go!
    Part numbers for the N122 are 8D0 905 351 or 4D0 905 351. There is apparently a difference between the '8' and the '4' models, however noone seems to be able to say what! My old AGU had the '4' so I suspect your may be the same...
