What to go for:- 2.7tdi S line or 3.0tdi Q S line
Discussion in 'Audi S4/A4/A4 Cab (B7 Chassis)' started by trekbiker, Aug 19, 2010.
  1. trekbiker
    trekbiker Member
    Apr 3, 2004
    421
    Folks,
    i'm finally switching back to the Ingolstadt product over the Bavarian counterpart.
    My budget is about 12k, ive seen a couple of the above advertised in different places.
    Which to go for? has anyone owned both for any length of time?
    I'm definitely after a 6 pot after owning a 2.5 B6 a few years ago.
    I would deffo map the 2.7, and possibly the 3.0 if i wnet for one of those
    2.7- advantages
    better mpg
    cheaper RFL
    2WD handling
    my budget would prob buy a year newer with same mileage
    disadvantages
    slower
    3.0 adv-
    Quattro handling
    quicker, more torque
    more fun per £
    disadv-
    lower mpg
    higher maintenance costs
    Does anyone have any further advice at all please?
    Marty
  2. Advert Guest Advertisement
  3. Johnytuono
    Johnytuono Member
    Jun 19, 2007
    132
    Hi
    I can only speak about the 2.7 tdi engine, I found that superb and to be honest I think your real issue is wether you want quattro or not. I don't think you' ll have a problem with either of these V6 engines. I should imagine maintenace costs are very similar. In fact I've just had an email from Audi for service costs (up to 3.2 engine) Annual service £199 and Variable is £349 so it depends on your mileage which is most cost effective for you.HTH
    JohnyT
  4. trekbiker
    trekbiker Member
    Apr 3, 2004
    421
    to follow on from the above, has anyone mapped a 2.7 tdi at all?
  5. Marc1
    Marc1 Member
    Feb 25, 2008
    731
    If performance was a major factor, I'm not sure why you would choose the 2.7 and then map it. I might be missing the point here though, I'm just not so sure what the point of the 2.7 is, it has a very, very small increase in power over the 2.0TDI 170, which I think is a better choice if you want front wheel drive.
  6. trekbiker
    trekbiker Member
    Apr 3, 2004
    421
    fair point, but aside from the sound of the V6, there are also the reliability issues. does the 170 2.0 suffer the same oil pump problems synonymous with the 140 2.0 tdi engine range?
  7. trekbiker
    trekbiker Member
    Apr 3, 2004
    421
    And do Revo or anyone else do cruise control stalk retro fit? io seem to remember that someone used to do it with the B6s?
  8. Marc1
    Marc1 Member
    Feb 25, 2008
    731
    Not sure TBH. If it was me I would definately go for the 3.0TDI as it has more potential in every area, however I am biased as this was the car I had planned to buy at the beginning of the year. I did want quattro however and tiptronic with paddle shift, both of which mean fuel economy would be lower and maintenance higher, so really depends what your priorities are. I just don't see the point in getting a 2.7 if you plan to map it. Although I do understand that you may want a smoother V6 engine than a 4 pot with front wheel drive to keep it more economical etc. I really don't think you'd be disappointed with the 3.0 though and a lot are specced very well. Cruise is an easy retrofit regardless of the engine. Speak to Ben from shark performance (used to be a forum member on here) or I can give you the details for a great Audi master tech Manchester way that could help you, he's on vwaudiforum.
    If you're concerned with reliability you could try and by an approved vehicle with warranty. I here the Audi warranty is pretty good at paying the RS6 boys out.
  9. Dazmo
    Dazmo Active Member
    May 9, 2009
    1,768
    3.0 v6 Tdi all the way.
    Maintenence costs are slightly higher, but as long as you look after it, it should'nt be a problem.
    Remember the 3.0 takes 8 litres of oil.
    The first thing i did with mine was change all my discs, pads, brake lines for a fraction of what audi would charge and now at least i know these wont need touching for quite some time now.
  10. trekbiker
    trekbiker Member
    Apr 3, 2004
    421
    Thanks guys, food for thought. I'm also throwing in the 2.0tfsi into the mix, looking at a quattro prob tuesday, and there is a 2WD locally too!
