What to get fixed before the warranty runs out
ollyhawkeye Jan 4, 2010
  1. ollyhawkeye
    ollyhawkeye Member
    104
    Morning everyone and Happy New Year!!
    I'm due for a service in a couple of weeks and my warranty runs out on the S3 in March so I figured this would be a good time to get some ideas around what should get fixed under warranty.
    I am pretty sure that the sagging diffuser at the rear is a warranty fix, has anyone else done that?
    Are there any other big fixes that I should look out for? Haldex orientated or otherwise.
    Your thoughts/experiences would be appreciated before I book it in.
    Olly
  2. magnus911
    magnus911 R8GGA
    453
    Hmmm. In a similar position so i'll tag on this thread! The locking clip on my arm rest snapped off so now it doesn't 'click' shut. Also the plastic thing fell off. That's a warranty fix right? Or will they tell me I snapped it off?
  3. maninthestreet
    maninthestreet Active Member
    170
    30
    What 'plastic thing' ???
  4. 330_2_S3
    330_2_S3 Member
    243
    My car is in the dealer now too... and warranty runs out march...
    But they are trying to bump me in the servicing price!!! (sorry to hijack thread) £382?!
    But yeah my rear washer has stopped working so they are fixing that too.
  5. magnus911
    magnus911 R8GGA
    453
    the plastic handle that you pull up with your fingers to open the arm rest. that's the bit that snapped off. But i didn't snap it because i pulled too hard. It just snapped off through plastic-fatigue if there is such a thing.
  6. ollyhawkeye
    ollyhawkeye Member
    104
    I would think that they would be fine with that. I had my rear pop up blind replaced with no quibbles when it snapped off....
  7. magnus911
    magnus911 R8GGA
    453
    Cool. Thanks guys.
  8. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    They won't replace trim under warrenty - my armrest is broken on one side as well
  9. smudge_don
    smudge_don Active Member
    2,944
    I want to get some things done on mine, will they replace:
    Brake pads
    Suspension bushes
    Glovebox catch
    Flywheel
    Gearbox
    Under warranty?
  10. Broken Byzan
    13,237
    465
    I would look at getting everything looked at you are worried about. Once the case is started, even if it takes 6 mnths for the OK it's still covered.
    It's your car and you know what is normal for it and what isnt
  11. smudge_don
    2,944
    Good advice
  12. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Get the steering rack checked, failed racks on the S3 are not unheard of.
    Also check you dont have excessive wear on your door seals due to the doors `dropping`. The dealer wil adjust the doors and replace the seals under warranty (had mine done once and needs done again:confused:).
    And Errr...anything else that you think isnt how it should be.:noway:
    Paul
  13. 330_2_S3
    330_2_S3 Member
    243
    Had my rack replaced under warranty, car was alot more responsive steering wise....creaking went too.
  14. crypric23
    crypric23 Never satisfied
    586
    its Audi at the end of the day !
  15. stealth64
    stealth64 Member
    201
    Mine is going in for a few tweeks next week, its covered under a 12 month used warranty. There is a bit of laquer thats come away on the o/s quarter panel under the mirror will this be covered?
  16. ollyhawkeye
    ollyhawkeye Member
    104
    Thanks Paul....
    What are the signs of the rack failing? will double check on the seals too!
    Olly
  17. JohnS3
    JohnS3 Active Member
    3,032
    How do you know if your doors have dropped?
  18. jsws3
    jsws3 Member
    440
    My door has dropped to so its going back to audi
  19. Iv had the gearbox replaced for a whine in 5th gear, steering rack and various other little things here and there. I have noticed that both my seats creak. If you put your weight on the back support then take the weight off they creak. If you are driving along a bumpy road you can hear then creaking. Going to bring this up when i drop my car at Audi on Friday, you dont expect creaking seats after 20k miles in any car never mind an Audi.
    Davie
  20. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    The door seals mid way down the main pillar door shut wear locally. Mine had worn through to a hole.
    Looking down the flanks the door is visibly out of line too.
    Its fairly obvious if your car is affected though.
    cheers
    Paul
  21. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Creaking, groaning, mechanical `play`. Thats how I understand it anyway.
    Paul
  22. Mine used to clunk if i moved the steering left to right when the car was at a standstill, also when going over bumps on full lock used to get a dull clunk. New rack solved the problem :)
  23. Andy88
    Andy88 Member
    109
    I brought this up on my last service as mine has snapped off too, i was told that i must buy the whole armrest again and to the best of my knowlege it was not cheap. If you find they are able to fix this or you find a place to buy a replacement it would be much appreciated.
  24. magnus911
    magnus911 R8GGA
    453
    will keep you posted...
  25. smudge_don
    2,944
    I managed to just buy the lid of the armrest off ebay
