what they worth?
dantheman1986 May 3, 2009
  1. dantheman1986
    dantheman1986 Member
    262
    got a set of front s3 calipers and carriers. ive stripped them back to the metal using elsectrolysis to remove all the rust. im thinking of either painting them (what colour?) or leaving them as they arr so the buyer can paint them the own colour. what do you guys think there worth?
  2. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    The carriers will be worth more than the calipers I think, the single piston calipers are the same as those used on the facelift A3's with 1.9TDI 130, 1.8T & 1.8TQ IIRC.
    The only difference is that they have 288mm brake discs whilst the S3 has 312mm.
    At a guess I'd estimate about £50 ish, maybe a bit more?
  3. dela
    dela Member
    262
    i'll have them off you for £50, just what i needed!
  4. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,154
    1,987
    carriers are what the golf guys use apparently when upgrading their brakes,mine are sitting in my garage :(
  5. dantheman1986
    262
    i think ill stick em on ebay see what they fetch, you guys reckon its worth painting them to make them look a bit more appealing?
