What the feck is that clicking noise at the rear of my car
g dawg Jun 8, 2013
  1. g dawg
    g dawg Member
    102
    After accelerating in 1st or second I get a random click from the rear it doesn't happen at idle it's doing me in
  2. coreythorny
    coreythorny Active Member
    455
    74
    Is it a S3? Could be the exhaust valve in the tailpipes.
  3. g dawg
    g dawg Member
    102
    Yeah it's an s3 it's a bit random I think to be the valve unless its got a mind if its own
  4. coreythorny
    455
    74
    Its normal mate, I heard it the first time when it was on the rollers. You learn to ignore it ;)
  5. g dawg
    g dawg Member
    102
    I think it's transmission related?
  6. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
    Does this happen just after the car has started and driven a very short distance?
    Does it just do it the once as well?
  7. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    As someone else has said. Exhaust flap in the L/H tailpipe opening and closing under throttle. Some are noisy some aren't. Makes a loud clicking noise. Just disconnect it and open it fully and lock-wire it open. End of clicking.
  8. Cozza McA
    410
    73
    Ah thanks for that, I don't have an S3. Only a 1.6FSI
    But every morning when I head out something clicks on my car an it always happens at the same spot.
  9. g dawg
    g dawg Member
    102
    Mine does after 1st gear 2nd gear probably more often than not but its random its just had new injectors and inlet manifold gaskets and it didn't do it befor that. It's sounded like the heat shield at first but it only does once warm and moving and it done it at biting point with the handbrake on. I'll try the opening the valve and go from there it may go back to Audi thanks for your help lads
  10. g dawg
    g dawg Member
    102
    What position is your valve in stationry and idling mine is open in both case's is it broken??
