what spark plugs for k04 hybrid
peterg60 Dec 9, 2012
  1. peterg60
    peterg60 Member
    31
    9
    hi all what spark plugs should i buy for my k04 hybrid build ? its a 1.8t agu engine in mk1 golf . also do they need gapping or can i buy then already to put into motor. thanks
  2. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    Ngk bkr7eix. Gapped to 0.7-0.8mm
  3. peterg60
    peterg60 Member
    31
    9
    wheres the best place to get these? are they pre gapped or i have to do them
    thanks
  4. lshigham
    lshigham Member
    42
  5. superkarl
    9,495
    2,436
    Got mine from ebay, 4 for about 20 quid I think. Being iridium they last longer tho so its worth the cost in my eyes. And yeh you'l need to gap them with feeler gauges
  6. Prawn
    11,538
    3,492
    stick BKR7E copper plugs in it mate. The copper version of what Karl suggestd.
    Copper dissipates heat better, which helps towards EGT's, and with a ko4 hybrid you're going to need all the help you can get with EGT's!
    As Karl said, the only benefit or platinum or iridium plugs is life span, plat/irid plugs will last 50k plus, where coppers need changing every 8k or so.
    However, the coppers are £2 per plug. I'd much rather spend 10 minutes twice a year changing plugs and know that I've got fresh ones than spend the extra initially and assume they're fine for 4 years!
    I run BKR7E copper in my 350bhp AGU, Tuffty runs them in his at 400bhp, and Welly ran them in Bumble at 450bhp too
  7. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    U got an eBay link prawn pal to these ones u use
  8. Prawn
    11,538
    3,492
  9. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Would the plugs you mentioned prawn be fine in a agu with 190bhp or are these more for higher power an if so with what gap I have Bosch super 4s at the min, sorry to jump in on the thread
  10. Prawn
    11,538
    3,492
    I would think the 7's would be fine on a mapped AGU yes mate, if there were a touch cold you could always try 6's, but I think 6's are standard.
  11. peterg60
    peterg60 Member
    31
    9
    thanks all i just ordered some cooper 1s and a feeler gauge from ebay.
    cheers
