What spark plugs are you using??
garyrmills Sep 28, 2009
  1. garyrmills
    garyrmills Member
    59
    ive checked through the search section for this with no luck. i was wondering what would be the best plugs to get considering my car has had a stage 2 revo remap? not sure if this would make a difference (wether they get hotter or draw more current) but thought id check before i invest in some.
    also anyone know the cheapest place to purchase some?
    thanks in advance gary
  2. RichA3Turbo
    5,089
    BKR6EIX - iridium plugs with 0.8mm gap. IK20's which some people use are 1.1mm gap and this can be too big...certainly caused me misfire issues when the engine was hot.
  3. scottmclees
    scottmclees New Member
    im using ngk laser platinum pricey but worth it i think
  4. garyrmills
    garyrmills Member
    59
    do you think there will be any affects from stage 2 remap? and is there a difference between s3 and a3?
  5. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i was using std ngk audi recomended plugs untill i blew a coil pack the other day and found that ngk bkr7e are the recomended plug for stage 2 there not platinum so need changing every oil change
  6. garyrmills
    garyrmills Member
    59
    which oil are you using as well as im looking to change oil and filter aswel?? thanks gary?
  7. S3KO4
    S3KO4 Member
    850
    Oil 5-30W fully synthetic. new audi & VW recomended
  8. s3_kev
    2,002
    23
    castrol edge sport
  9. garyrmills
    garyrmills Member
    59
    wheres the best place to get hold of the ngk bkr7e as cant find them and asked a few local shops and they dont have them ?
  10. garyrmills
    garyrmills Member
    59
    is there any particular pitch of thread or specifics to the ngk bkr7e as everywhere is saying there not for an s3? just wondering if its a particular type of fitment thanks gary
  11. Y83OLK
    Y83OLK Hulk Smash!
    841
    NGk pfr7q gapped to .8
  12. garyrmills
    garyrmills Member
    59
    couldnt be a pain but could someone send me a link to any of these plugs ive been looking and there all for different cars grrrrrrrrrrr
  13. s3_kev
    2,002
    23
  14. Prawn
    11,508
    3,419
    I'm using denso IK22's gapped to 0.8mm, and they're been fine for 30k without being touched once!
  15. garyrmills
    garyrmills Member
    59
    sorry if im being thick but how would you adjust the gap ?:think:
  16. banoffee
    banoffee Member
    124
    feeler gauges and a wooden doorframe work for me :happy:
  17. Y83OLK
    Y83OLK Hulk Smash!
    841
    PFR7Q are whats recommended for an s3, but BKR7E are the not platinum equivalant...so will require changing more often.
  18. simch
    simch Active Member
    2,028
    Actaully, the "7"s in NGK are cooler than the stock which is a "6" plug, (from audi).
    I use the 7s and use the cheap as chips BKR7Es just change every 7k miles
  19. Y83OLK
    Y83OLK Hulk Smash!
    841
    Its also worth bearing in mine when converting from platinum to copper you should go one heat range hotter.
    So i would have though BKR8E be a more popular choice lol
  20. conti
    conti New Member
  21. finesse
    finesse Active Member
    2,805
  22. Sandip
    2,450
    91
    Bosch Super 4 FR78's
  23. finesse
    2,805
  24. Sandip
    2,450
    91
  25. jonny87
    jonny87 Active Member
    1,094
    ngk bkr7e's on mine mate, need changing every oil swap but are cheap as chips off ebay (£10 for the 4 iirc)
  26. finesse
    2,805
