What spacers are you running?
*P3nfold* Feb 5, 2013
  1. *P3nfold*
    *P3nfold* Member
    368
    15
    I am current running 18in 8j RS4 reps with 225/40s on front and rear.
    The car just does not look right what spacers are you running front and back?
  2. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    I have the original RSTT rims, with 15mm spacers all round, mine looks good, maybe I should lose the fronts to 10mm though, then it'd be spot on.
  3. *P3nfold*
    *P3nfold* Member
    368
    15
    Cheers buddy, I was looking at 20mm for the rears and 15mm for the fronts, might be too much poke as I want my looking flush.
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    10mm front and 15mm rear.
    Go wider and expect your paintwork to suffer even more stone chippage than mine has.
  5. jay1
    jay1 Member
    168
    I have 18"rstt I have 20mm front 30mm rear
  6. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    170
    I have genuine RSTT`s so et35
    and have 20mm rear and 15mm front and it looks spot on I think
  7. *P3nfold*
    *P3nfold* Member
    368
    15
    Looks mean.
    Do you have a picture bob?
  8. vrbob
    2,375
    170
    Good question will go look on photobucket........
  9. vrbob
    2,375
    170
    On my other wheels same et35 as also genuine but TT wheels
  10. *P3nfold*
    *P3nfold* Member
    368
    15
    Looks good Bob, its a win win as I found a set going cheap the same as yours.
  11. vrbob
    2,375
    170
    Yeah I got a bargain on both fronts as my full set of hub centric spacers including longer wheel bolts and a longer locking bolt set cost me £100 off the classifieds on here and were as new when I received them.
    My 17" TT (proper ronal ones) wheels were an ebay bargain as only 20miles from my house and got them for £140 and they had been refurbed in the same grey colour as found on the centre caps and only one had a slight mark on it tyres were reasonable too but have worn them flat now lol
    I do love a bargain me :)
  12. *P3nfold*
    *P3nfold* Member
    368
    15
    Just got 20mm FK and 15mm 5x100/5x112 both sets with M14 longer bolts for £55 collected.
    Totally with you on this they are deals to be done at the moment.
  13. vrbob
    2,375
    170
    Good work fella :)
  14. vanilla_ice
    vanilla_ice Member
    692
    21
    New? Got linky?
  15. Blackcupraa
    Blackcupraa Member VCDS Map User
    183
    13
    Jay1's set up looks awesome.
    I currently have 15mm front and 20mm rear, may put the rears on the front and invest in some 30mms for the back.
    jay1 likes this.
  16. ci-ryder
    ci-ryder Member
    199
    Have 19's and 35mm spacers front with 45mm on the rear.
  17. PaulRS3
    PaulRS3 Well-Known Member
    1,203
    138
    I used to run ( with genuine Audi 18" 9 spoke RSTT alloys)
    10mm front ( with Porsche Big reds)
    15mm rear.
    There was only a credit card thick clearance between Porsche caliper and rear of the spokes, but worked well over 2 cars/10 years
  18. *P3nfold*
    *P3nfold* Member
    368
    15
    Cheers guys, I got the 20mm rears and 15 fronts, I'll get some pics up this weekend.
  19. vrbob
    2,375
    170
    Good work M8 :)
    Oh and you do know the pedal on the right goes all the way to the floor don't you? cos how the hell are you averaging 34.4 mpg!!!
  20. *P3nfold*
    *P3nfold* Member
    368
    15
    I treat my car like I treat my women, slowly until I upgrade the parts, then I take them for a good thrashing.
  21. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    58
    Doing well, but on the other hand the only reason mine was so low was when the stat packed in & it ran cold for a week.
    Defo pulled the MPG's down!
  22. L55DSW
    L55DSW Member
    39
    Has anyone got a pic of a S3 running standard wheels with a 15mm / 20mm setup..??
  23. Sidey
    Sidey Active Member
    284
    152
    43
    What spacers do you guys recommend running with original Avus wheels?
  24. *P3nfold*
    *P3nfold* Member
    368
    15
    Well guys, I fitted the 20mm on the rear this morning, the car looks better for sure, a little poke at the rear which is so,so I am hoping for no tyre rub lol. Fitting the 15mm at lunch time so will post up pictures then.
    The ET on the fronts was 37 and its now 22.
    The ET on the rears was 37 and its now 17.
    Do you have to get four wheel alignment done?
  25. Prawn
    11,354
    3,190
    your reps were ET37? N wonder they looked extra cack.
    Just to correct VrBob above, I'm pretty sure genuine RSTT's are ET32, and the 17'' TT wheels he posted pics of are definitely ET32 not 35, but they're also 7.5J so it's irrelevant when comparing to RSTT's at 8J.
  26. *P3nfold*
    *P3nfold* Member
    368
    15
    Cheers Prawn, this that a technical response on my fakes lol.
  27. S3 zombie
    S3 zombie New Member
    19
    My genuine 18inch rstt's 8js are defo et33.. i run 20mm front to clear the 6pots and 25mm on the rear...et8 on the rear does sound exessive but its well inside the arches even with adjustable tie bars..the fronts are flush (just)
    phil..
  28. *P3nfold*
    *P3nfold* Member
    368
    15
    Just looking at front they dont have any spacers and I am running 4pots with 330 discs but 8j rims.
  29. vrbob
    2,375
    170
    Prawn is right (again lol)
    My TT wheels are 7.5J and et of 32
    The RSTT`s are ET 33 and 8J
    MY RSTT`s do sit a bit better than the TT wheels in the arches too
  30. <tuffty/>
    20,767
    3,650
    OE RSTT's are 18x8 ET33 and OE Avus are 17x7.5 ET32...
    I use 10mm front and 15mm rear hubcentric spacers for both my AVus and RSTT
  31. *P3nfold*
    *P3nfold* Member
    368
    15
    Fitted 20mm at the rears and 15mm on the fronts.
    Final ETs are actually. I checked the ET again lol.
    The ET on the fronts was 35 and its now 20.
    The ET on the rears was 35 and its now 15.
    Just need to wait for the suspension to settle to see if the right decision has been made. There is a little poke all round, feel like a scene whore.
  32. L55DSW
    L55DSW Member
    39
    You have any pics of them fitted mate??
  33. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,243
    348
    :motz: another wheel thread where people don't seem to realize that you need wheel width, wheel offset & spacer size in order to compare wheels/stance. ffs
    my wheels are round shaped - what size spacers do i need
    :undwech:
  34. Sidey
    Sidey Active Member
    284
    152
    43
    Mind posting some pics? Would like to see how much poke you have with that final offset.
  35. *P3nfold*
    *P3nfold* Member
    368
    15
    Sure,
    Passenger side
    Drivers side
    I am going to change the fronts to 10mm due to preference.
  36. Sidey
    Sidey Active Member
    284
    152
    43
    I actually like that, looks perfect.
  37. limbo118118
    limbo118118 LORD
    490
    52
    I got 18" 8j with 225/40's with 35mm on the back... Did have to roll arch a little tho but looks mean, an just trying to decide what spacers for the front :s
  38. Sidey
    Sidey Active Member
    284
    152
    43
    What offset are the wheels originally?
  39. limbo118118
    limbo118118 LORD
    490
    52
    Et35 mate
  40. Sidey
    Sidey Active Member
    284
    152
    43
    So final ET 0 then?
