what spacers are people running?
limbo118118 Dec 7, 2012
  1. limbo118118
    limbo118118 LORD
    503
    53
    hi, my car is sitting pretty low on coilys, an on 18'' 8.0 et35 dare lp560's wheels, but as you find the wheels on the rear are sitting well too far in the arch, an on the front there still in abit, so just wondering what size spacers people are using!?
    or is there an easy way to work this out?
    im guessing its gotta be around 45mm on rear with 20mm up front? iv tried measuring but with the wheel sitting in the arch so much its hard to get an exact measurement,
    im after this sort of look with the wheel sitting out a little bit, my tires are stretched a little bit also.
    any help would be appreciated! :)
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    25F, 40R
    what tyres have you got on them
  3. limbo118118
    limbo118118 LORD
    503
    53
    205/45.... i would of thought it woiuld have needed bigger on the rear? got any photos of yours?
  4. Alex C
    3,297
    373
    my wheels are 8.5" ET25 and i have 10F 20R spacers on mine. Tyres are 225/40/R18
  5. Alex C
    3,297
    373
    if you went for 45mm on the rear then they would stick another ~8.65mm out further than mine do. With 40mm spacers then obviously they would only stick out another 3.65mm further than mine do in the pic.
    I think mine stick out plenty enough as they are. If i had a wider wheel/tyre then i could probably get away with more poke without it looking odd. But you have 8" wheels with 205mm tyres. Something to consider...
  6. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I used to run 10 front and 25 rear,
    It just made the car sit right.
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    30mm all round on jap wheels
  8. S3 Paul
    2,825
    107
    My porsche adaptors are 40mm but the offset on the wheels is around 52 so going as wide on standardish offset... a little bit wild me thinks
  9. Alex C
    3,297
    373
    what are the width of your wheels Paul?
  10. limbo118118
    limbo118118 LORD
    503
    53
    Ah i seee! So im thinking 35mm rear. An 20mm front, hopefully should get as close to the set up you have!?
  11. Alex C
    3,297
    373
    20mm on the front would sit a further 6.35mm inside the arches compared to mine. No bad thing - my fronts chuck mud up the doors and the side windows because of how far they poke out. It's the price I paid for squeezing Brembos under dished wheels
