What size spacers
dubindan
So I've got handr springs fitted and bilstein b8 shocks I've got some rep bbs ch alloys fitted with 225 40s the alloys are et 45 so what spacers can I have without rubbing also where do I get them and the bolts from thanks guys dan
Yh they are 8 inch wide what makes you say not to bother they sit in a lot thanks dan
And that's okay with then being et 45 offset ? How much is this going to cost me then also with correct bolts do I need to take in to counter that the oddest is Diffrent to standard so the bolts will need to be slightly longer on top of the spacer length if you understand thanks dan
If nothing is rubbing, are there any advantages to adding spacers apart from aesthetics? i.e. Improved handling?
I was going more for looks tbh bringing the wheels out to the arches will make it look lower and look a lot better
622
DPM
867
9
