What size spacers on ET 50
iantype-r Nov 14, 2013
  1. iantype-r
    iantype-r Member
    52
    Hello all,
    I'm picking up some 15" alloys. They are ET50, as I'm going to probably be very close or just touching any rough idea what size spacers to get. I assume I will have to get longer bolts also,
    Cheers Ian
  2. Wheelmanwayne
    Wheelmanwayne Member
    64
    12
    I'd run 15-20mm on such beast's as its only a 6.5j even a 25mm would fit
  3. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    Will they even fit over the brakes?
  4. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    That is what I was thinking. 15s are really small....my 17s just clear my fronts which granted are 312mm but still.
    Otherwise try and get the ET to about 35ish
  5. Wheelmanwayne
    64
    12
    Audi did make a 15" option for the lower base model a4 1.8 n/a so if your engine size is larger I'd trial fit before you buy to be honest
    These are them
  6. quattrojames
    14,068
    585
    15" wheels will fit 288 discs, but you'll need 16's if you have 312mm.
  7. iantype-r
    iantype-r Member
    52
    Thanks for the replys guys. I'm going to try them first to see if they fit
