WHAT SHOULD I DO COZ IT LOOKS LIKE AUDI HAVE COCKED UP.
shady-ninja Mar 7, 2013
  1. shady-ninja
    shady-ninja Active Member
    999
    53
    took my car to Audi last December coz the clutch was slipping.
    Audi dismounted the gearbox & decided not to replace the clutch under warrantee coz
    it appeared not to be a manufacturing fault then put the gearbox back together.
    2 days ago i tried to use the aircon only to find out its not working.
    did Audi need discharge the refridgerant to dismount the gearbox?
    if they did, then why did they not replace the refridgerant OR AT LEAST inform me.
    prior to this the same dealer changed my compressor under warrantee
    which is less than one year.
    what should i do?
  2. Lewis583
    956
    91
    AC shouldn't need degassing when removing gearbox.
    Is the car still under warranty? If it is, take it in.
    If it ain't get the specialist, assuming they have the equipment, to find where the leak is in the system. If its anything compressor related, then take it to the dealer. If its nothing to do with the compressor and the car is out of warranty, they may charge.
