What RPM should the A3 170 pd spool up/kick in at???
Simon170TDI Aug 30, 2012
  1. Simon170TDI
    Simon170TDI Member
    62
    As above what RPM should my turbo kick in.. Think it may be kicking higher than it should :/ any advice I'm a new diesel/turbo man
  2. Cossie_boy
    Cossie_boy Member
    472
    ill check on way to work tomorrow but about 1500 i think?
  3. Sheikh
    Sheikh Member
    654
    20
    My 140 used to be alive and kicking from about 1500 rpm didnt like high revs much though.
  4. Ash187
    7,496
    744
    From what I have seen the turbos on the diesels kick in around 2500rpm before that it's pretty dosile unless you have it mapped
  5. Djwoody
    Djwoody Member
    481
    21
    My 170 version is mapped and kicks in around 2200rpm I think.
    Is this about normal? I'd love it to kick in a bit earlier. It's pretty flat till I hit that.
  6. The Governor
    The Governor Active Member
    527
    75
    Ho can you tell when the turbo kicks in?
  7. max69vk
    max69vk Active Member
    862
    57
    Mine seems to kick in a bit lower than Ash at around 2k rpm. You'll know when the turbo kicks in as thats when the car starts to pull a lot harder. (non-remapped by BTW).
  8. Sidhu88
    Sidhu88 Active Member
    808
    76
    Begins to spool at 1500, full boost around 2000-2250. 3rd gear pull from low rpm will help u figure it out. keep ur window open and ull be able to hear it spool then hear when its at full boost
  9. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    According to Audi UK brochure Edition 6.0 04/11 2012 year models (factory spec / unmapped obviously!)
    1.6TDi (105PS): Max power 105 PS at 4400rpm, Max torque 250Nm from 1500-2500rpm
    2.0TDi (140PS): Max power 140 PS at 4200rpm, Max torque 320Nm from 1750-2500rpm
    2.0TDi (170PS): Max power 170 PS at 4200rpm, Max torque 350Nm from 1750-2500rpm
    Suggests to me that 140 & 170 run the same turbo as the torque curve and max power RPM is the same.
  10. Cossie_boy
    Cossie_boy Member
    472
    Yeah after today I would say about 1700/1800 n mine is standard
    I have noticed in traffic it doesn't like it if you go into second too soon, bit of kangarooing, anyone else found this?
  11. warren_S5
    7,210
    2,487
    My brother in laws 170TDi does this. It's 58 plate, 65k miles, and he's having numerous issues with:
    > Engine Management Light coming on
    > Stuttering / Kangerooing in lower gears, esp. not long after it's started
    He's had the injectors replaced by dealer under warranty, but it's never 100%. Short journeys might be part of the problem, but it's not been a great ownership experience for him.
  12. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    1800 mate even after I did a remap it has remained the same.
  13. RedDejavu
    1,806
    337
    In my case new injectors completely cured the issue.
  14. Rhyso
    Rhyso Well-Known Member
    1,518
    315
    If its the PD 170 it will start spooling at approx 1500rpm. Max torque is produced at about 2500rpm.
    The 140 produces max torque at approx 2000rpm
  15. Vertigo1
    Vertigo1 Well-Known Member
    3,623
    714
    My PD170 suffered from stuttering quite a bit but only when the DPF was in one if its regeneration cycles. My current CR170 doesn't do this at all. I think the DPF tech/system in the PD170 was very new and still had quite a few issues whereas they've sorted it out a lot now. I had loads of issues with noise and harshness on the last car but none at all with the new. The only real giveaway that it's doing a regeneration cycle is the engine idles at 1000rpm rather than 800.
  16. Cossie_boy
    Cossie_boy Member
    472
    Strange how its caused and cured problems for different people!
