What power should i think about adding an extra fuel pump?
jasongtr Jun 24, 2014
  1. jasongtr
    jasongtr Active Member VCDS Map User
    441
    37
    Im building a 4wd (haldex) mk2 golf, it to begin with will have a BAM engine, due to the haldex conversion there won't be room for the standard fuel tank, so I'm having a fuel cell built that will accept the standard A3/Mk4 fuel pump, so a couple of questions.
    1. is the main fuel pump (drivers side) from an S3 ok to use with just this part - so not having the passenger side plumbed and plugged in (maybe the passenger side is also part of the level sender???)
    2. at what power level do i need to worry about using a front wheel drive A3/Mk4 golf Gti fuel pump, if it can handle 280hp then ignore the 1st question, as if i up the power down the line i can add an additional inline pump and fuel pressure regulator.
    cheers
  2. Gary_808
    Gary_808 Member
    166
    I'm doing the same thing, haldex mk2 that is,
    I'm going with a single external 044 pump in a sumped tank, good for 500-600bhp if I go above that I have a nice aeromotive pump laying about.
    I know that's not answered either of your questions but another option.
  3. jasongtr
    441
    37
    I've considered the complete external pump option, but a for couple of reasons would rather try and use a std pump, i break mk4's and a3's so having replacement pumps is easy, and I'm also putting a full S3 dash in so having a factory fuel gauge appeals too
  4. snowy
    snowy Active Member
    418
    101
    43
    Systec do a decent rated replacement
    The S3 (and all the AWD mk4s) have a 2nd level sender attached to the venturi pump in the 2nd half of its saddle tank - if its not attached I've heard the fuel gauge has issues
    The LCR swirlpot and sender unit might be safer bet
    You could try with a standard LCR pump - if that doesn't do the just get one of the systec drop-in replacments
  5. jasongtr
    441
    37
    ok cheers ill check it out, does anyone know the power limitations of the A3/mk4 gti pump?
  6. snowy
    snowy Active Member
    418
    101
    43
    they seem to start having problems after circa 220hp
  7. jasongtr
    441
    37
    1 wont be using one of them then
