what power should i expect
s3welshy Nov 7, 2013
  1. s3welshy
    s3welshy Member
    60
    Hi all.
    I have a 1999 s3 8l. It has badger 5 tip, s2000 airfilter, n249 delete, and a revo re map.
    Im having the car rolling road run at the end of the month. What sort of power do you guys think I should get?
    Thanks all.
  2. aragorn
    17,956
    701
    250hp
  3. chaz20vt
    chaz20vt Member
    428
    21
    Mine was rolling roaded at 252bhp i don't have a badger 5 tip though but do have a 3" cat back
  4. <tuffty/>
    20,847
    3,687
    Hugely subject to condition of engine/turbo/pipework etc... make sure you are using decent fuel (v-power)... also depends what revo settings are in there... some people just turn everything up to max without checking... you can actually get less power from doing it that way..
  5. jojo
    28,831
    3,485
    Depends on whose dyno you go on?
    Revo Steve-W, voorhees and badger5 like this.
  6. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    My car is a similar spec and is running 254bhp.
  7. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    I got 280bhp with less mods on some happy dyno.
    If I were you I would try and lend an sps switch to turn it back to stock,try it then and go from there for a better reading.
  8. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    If you need an sps I have one welshy. Where are you getting it dyno'd by the way?
  9. Adam P
    Adam P Active Member
    539
    178
    43
    I would guestimate around the 250bhp mark like the others have said, however it would be interesting to see you results and chart if you could post them up afterwards?
    Adam
  10. IrishDave
    IrishDave Active Member
    682
    45
    240-260hp, depending on condition of engine and of course dyno lottery.
