what power should i be making
jonno123 Nov 19, 2012
  1. jonno123
    jonno123 Member
    99
    hi all ive got a 1.8t pre 2000 agu STD K03 with these mods
    BIG ITG FILLTER
    FMI
    DV FORGE 007 (BLUE SPRING)
    FULL PIPER 2.5 INC EXHAUST WITH SPORTS CAT
    EMERALD STANDALONE ECU
    I GOT A POWER READING OF 185 BHP AND 240 LBFT IS THAT RIGHT ? OR SHOULD IT BE MORE ?
    IVE JUST SENT MY K03S HYBRID TURBO OFF SO WILL GET IT BACK SOON GET IT FITTED AND REMAPPED
  2. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    OMG WHY ARE WE SHOUTING!
    Anyway.. you make more than 150 bhp, so that's a good thing, you don't mention that your car is mapped..
    Can I ask why you are using standalone management instead of the standard management?
  3. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    imo, everyone in the world should be running at least 500 bhp.
    so based on that, you are quite a way off. sorry
    coatesy likes this.
  4. jonno123
    jonno123 Member
    99
    Very sorry for caps ,
    yes car is fully mapped , because you can do so much more with standalone management and you can throw the maf in the bin plus i can map it myself knowing ive done a very good job :)
  5. superkarl
    9,571
    2,464
    clearly not if its only producing 185 lol
  6. jonno123
    jonno123 Member
    99
    the mapping on it is 100 % perfect !
  7. superkarl
    9,571
    2,464
    with that 'stage 2' sort of spec, with the intercooler, full exhaust, and induction upgrades, a ko3 is capable of 210 with a push from an experienced tuner.
  8. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Yeah, fact SK.
    This is probably a baaaaad forum to be talking of binning off the standard management, the reason you THINK the standard management isn't up to the job is because you have clearly always been to incompetent "tuners" who haven't got a clue about ME and couldn't map their route to work let alone map a 1.8t.
  9. 16Klappe
    5,795
    1,186
    To be fair SK I think you are 10bhp up, 200bhp is the realistic maximum for a K03.
    How can you say the mapping is 100% spot on, got some logs?
  10. badger5
    9,556
    2,028
    all this talk about slating a stand alone ecu, vs bosch me whatever
    you have no idea what health the turbo has..
    very often agu on tired k03 will make that sort of power levels...
    no idea on how hard its been asked to perform or anything
    insufficient information to say either way, but 185bhp is'nt unusual for a stage 1 tuned agu on old turbo
  11. superkarl
    9,571
    2,464
    i dont slate stand alone.
    i praise the guy for doing it and having a go.
    all im saying is he should aim for more, using healthy cars for examples.
  12. jonno123
    jonno123 Member
    99
    because ive mapped it , i have spent alot of time mapping cars , i was taught by one of the best in the mapping world and i do it for a job and have done for 5 years now , some of you might know of a vw corrado with a r32 turbo owned by richard who is on this site, i mapped it 620 bhp car runs fine no problem ive mapped alot of cars never had a problem ,
  13. badger5
    9,556
    2,028
    Question for jonno123.... What boost are you running it to and what duty cycles is it taking to achieve this?
    any dyno plots to show how it spools and holds boost for example?
    is the k03 tired?
  14. badger5
    9,556
    2,028
    Standalone's can work very well when not incumbered with a lot of the bosch nonsense for factory smoothness
    the op's happy with it, can adjust it Himself,
    What none of us know from the little information provided is how hard its being driven in mapping terms
    more info req'd
  15. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Agree. If I had the money I would be fitting DTA management to the track car.
    If I had a little less money I would be retrofitting ME 7.5 management and a DBW throttle.
    However, I have no money, so ME 3.8 it is.
    Choices choices.
  16. jonno123
    jonno123 Member
    99
    i will get a graph up asap , teh n75 valve is set too 100 % i think the turbo is worn out and the fact it still has a std tip cant be helping ive got a k03s hybrid being built at turbo technics , ill get it fitted and mapped and see if it makes any were near the 240 bhp mark
  17. jonno123
    jonno123 Member
    99
    boost peaks at 17 psi at 3000rpm and drops to 8 psi at 6000 rpm
    afr is 12.1 and ignition is set so min ignition for best power
  18. badger5
    9,556
    2,028
    duty cycle max'd is your answer... Depending on what the actuator pressure only is...
    slow to spool is another clue
