What power can standard clutch take? QTS
matt_simo1 Jan 6, 2014
  1. matt_simo1
    matt_simo1 Member
    79
    Hi all, the clutch has finally given up and now its time to spend money when i really dont have it.
    I was wondering if you guys new the max power a standard OE Type clutch can take.....now mines not been re mapped yet but once its done ill be lucky to go from 180 to 230 bhp......im not going anymore so do you think the standard clutch could take it?
    I really dont have the money for a uprated one?
    Thanks guys
  2. aragorn
    18,036
    723
    If your not changing the turbo, then you wont see over 200hp.
    Standard clutch will be fine if your keeping the stock turbo.
    Regardless of how you do it, get a gearbox input shaft seal, and a rear crank oil seal, as its pretty common to pull the box off and find one or both leaking.
  3. matt_simo1
    matt_simo1 Member
    79
    Ahh ok cool, im not changing the turbo no but have done De Cat and full Miltek exhaust system as well as a few other bits.......so you think realsistaclly a little over 200? But still standard clutch will take it. Thanks Aragon................again
  4. matt_simo1
    matt_simo1 Member
    79
    realistically***
  5. Broken Byzan
    13,237
    465
    nope still around 200
    the K03 is flat out at that
  6. aragorn
    18,036
    723
    A happy (lying) dyno will see you over 200, but a decent reliable truthful one you'll probably not break the 200 mark. I think the most recent person to try was Rob, whose car had all the bolt ons like exhaust intercooler etc etc and make 198hp and simply wouldnt do any more.
  7. matt_simo1
    matt_simo1 Member
    79
    Ok thanks Aragorn, Rob who? may i have his name soi can ask where he went to get it re mapped right with 4 wheel rolling road?.....im surrey way so want to know of a good recommended place for future reference.....ive ordered those oil seals and will be doing clutch this weekend :)
  8. aragorn
    18,036
    723
    Think his nick on here is Arrkon or something.
    He had it mapped at RTech.
